Transcend (589307) Media Logo
A
Anonymous Posted on Jul 01, 2010
Morning sir! what will happen to my data in my
Morning sir! what will happen to my data in my pendrive when I format the pendrive?
TurnerXobn0
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Nov 09, 2015
TurnerXobn0
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
706
Points
6
Hello, you just have formatted your pen drive without extracting data inside at first? Why do you have to format that USB pen drive without rescuing data out? Is it asking you to format and its file system become RAW weirdly? OK! No matter why you have to format that USB drive, the data stored inside after format often will not really be completely wiped.
Without fresh data to overwritten it all there, you do get chances to recover lost from this formatted pen drive with Pen drive RAW file system recovery software which often will deeply scan your assigned flash drive and take all possible recoverable stuffs back.
Therefore, do not give up and go search for related data recovery software to go on.
Hope you can make drive data backups well before any format.
Anonymous
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
Sniper:
  • Expert 67 Answers
  • Posted on Jul 01, 2010
Anonymous
Expert
Level 2:
Mentor:
Sniper:
Answers
67
Questions
0
Helped
21703
Points
275
All your data will be erased & used space of your pen drive will restore to 0 bytes.
2answers
Sir, I have TDK 4 GB Pendrive. I was formated some
this the great solution... try low level format..
1. plug ur usb flash
2. run Formatter v2.9.0.9.exe
3. follow the instruction and wait for the format (might take 5min for 4GB)
4. after complete, may the small volume (about 2MB...here the solution
5. plug your usb flash on other computer and format like regular (make sure u untick quick format) and click on "restore device defaults" then click format
6. now your usb flash drive was like a new one
Dec 14, 2009 • Vacuums
2answers
Transcent 8gb pendrive formatting problem
Try the drive on different machines. If you get the same error on all machines, you'll have to format the drive to reset the File system
2helpful
CANNOT DETECT 4GB PENDRIVE
Hello sir,
If you want to recover the Data and pendrive memory.you can format ur pendrive with there original software which you can get from following link..
http://www.transcendusa.com/products/online_recovery.asp
Enable to format my usb pendrive
your pedrive contains {Autorun} virus that's why you are unable to format it to view this virus go to view option in control panel then view and tick the show hidden file and folder
you can remove this virus
install malwarebytes and scan your pendrive
when you remove the virus format your pendrive
IF it not works
I think you use windows xp that's why it happen
Try to format in windows vista .or in windows 7
5helpful
3answers
Problems with pendrive data gets corrupted
Why not backup your remaining data from the pendrive. Then reformat your pendrive using full format. If it still behave like that , your pendrive is already giving up.
Error Message re: KIngston 2G Pendrive
since the device uses usb power there is no way that you might be able to retrive data if the computer wants to format it.
HELP ME! PLS
my 32 gb kingston pendrive not formating,and the data in pendrive not opening it shows that the source file is missing.
3answers
Pendrive write protection removing
Hey, the transcend pen drives usually have a small switch on the side of it, ie to turn the write protect on and off, usually a small lock symbol on it, the problem with unreadable files names etc, could be a corrupt partition, i would suggest formatting the drive as long as you aint got any important information on it,
All the best
John
74helpful
8answers
Problem detecting transcend pendrive
On opening my pen drive it displays "Pl insert a disk in drive G
Top Transcend Electronics - Others Experts
Bill Eager
NOEL
NOEL
Larry
Are you a Transcend Electronics - Other Expert? Answer questions, earn points and help others
