You do not change the drive oil on these tractors. It is supposed to be good for the life of the mower according to sears craftsman.
I finally took off the body because the pin you pull out in the back was not unlocking the transaxle either. I found two filler holes. Filled them up and it runs fine. Must have a leak though cause I have to fill it up about once a month but it's much less costly than replacing the trans. Now that I know where the filler holes are I can fill them with the body on.
So where are the holes , how much oil and what oil do you use ?
Thank's
