The answer to your question is: Look in your Owners Manual,there should be a section that covers belt installation or check the mower deck,there should be a decal showing how to install the belt around the pulleys. Sincerely,Brad LockeThe answer to your question is: Look in your Owners Manual,there should be a section that covers belt installation or check the mower deck,there should be a decal showing how to install the belt around the pulleys. Sincerely,Brad Locke
You can't post conmments that contain an email address.
I do not have a diagram,but I do know where it goes.Look at the tension pulley.The arm it is mounted on move.That arm is where the spring belongs.First move the arm with your hand.pull it so that the blades are not engaged.Now the side of the arm away from the pulley and closest to the rear of the mower,is where the spring goes.There may be several holes,do not pull the spring too much,just get it in one of those holes.Then try the blades.If they do not engage,move the spring,to another hole.
as far as i know, there is no diagram available for the cable replacement. it is covered briefly in the owner's manual, but the best way to do it is to study carefully how the old one is routed, and replace a step at a time
hello otto i would check the belt that runs to the rearend but the brakes could be also froze up i would try to jack it up & see if it will move then go from there
If you disengage the Blades like you normally would, this will give you plenty of slack in the belt to put back on. There should be a pulley or lever that tensions the belt when it is engaged and that is what is causing it to be too tight to put back on. Hope this helps
