Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
What does f-5 mean when flashing at me and won,t let me have my washing out the machine also washing really hot after a fast spin programme
  • Anonymous Mar 29, 2014
    Candy washing machine (cm1612) on 40 wash washing steaming hot and programme taking a lot longer than normak
    Genius:
  • Hotpoint Master
  • 1,481 Answers
If water is in drum then door wont open,drop drain hose to floor level into bucket to drain manually, then check filter or pump is it running ok if not is it stuck some thing in it , hot wash is cold water inlet ok or is this due to again faulty pump ...
Posted on Jun 25, 2010
  • hanszinderfa Jul 10, 2011
    Good solution. Mine was showing this fault code, followed the instructions and found a small rubber band wrapped around the shaft of the pump impeller. Had to dismantle the pump to remove it, reassembled and found the problem resolved. Thanks - saved me a small fortune
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
Machine stops after washing shortly before draining/spinning and control LED flashes 3times - "pump timeout exceeded" is what this error code means.
Just out of curiosity are both the hot and cold turned on... mine has an over ride if one is off and does the same thing
Aug 02, 2015 | Washing Machines
What does this mean? My machine is very new & won't drain it won't go through a full cycle & won't spin properly now it's bleeping with this flashing up on it!
Turn off machine and check water waste filter to see if blocked should be at front at bottom of machine or at back,not sure this is the cure but hope it helps
Apr 06, 2013 | Washing Machines
Can I just run machine on spin cycle?
Yes you can , almost every washer made now has a seperate spin only programme.
Some have the option of a fast spin, or a slow spin programme.
Dec 31, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
I have had aqarius a hotpoint aqarius 1000 wm62p
It has a wide variety of wash programmes for white cotton, colourfast cotton, polyester, non-colourfast cotton, wool blends and wool itself. These standard programmes take from an hour and a quarter to three-quarters of an hour to complete.
There is also a quick wash programme lasting just under half an hour for lightly soiled items and a pre wash soak for heavily soiled items. The machine has four buttons providing extra facilities that can be set independently of the main wash programmes to give you a more comprehensive range of settings.
There is a rinse hold button, which I find extremely useful. When set this holds the clothes in the final rinse water until you are ready to unload the machine. You then release the button, let the machine go through the final spin and then you can unload the machine. It means that you don’t leave damp washing in the machine for the time between the cycle finishing and you unloading the machine, which would make for very creased clothes. There is also a button to depress if you want to use the super rinse facility. This merely increases the volume of water in each rinse so that the clothes are rinsed more fully. I have never used this particular facility, as the ordinary rinses are fine for my needs.
The next button allows for a slow spin. I find that this one is really useful for the items that I need to iron as it means that they don’t come out of the washing machine as creased as they normally would on a faster spin. The only problem with this is of course that the clothes are not as dry as they would otherwise have been. The final button is used to set the economy wash feature. This means that the washing machine’s own heating system is not used and the wash is done with the water at the temperature entering the machine from your hot and cold water tanks. This of course means a cooler wash so it’s only suitable for lightly soiled items.
The door remains locked during the wash programmes so that it cannot be opened accidentally and it can be locked when not in use too if you have small children who might get into mischief! The other big selling point for this particular model is that it gauges the size of the load and uses the correct amount of water needed eliminating the need for the half-wash programme. This also means that it is both water and energy efficient
Mar 25, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
346 people viewed this question
Top Hotpoint Washing Machines Experts
Eric Taylor
Richard C Cohen
Richard C Cohen
Onofrio Taverna
Onofrio Taverna
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
