I turn the tv on.....I get a blue screen that says "no signal" and then 5 seconds later the TV turns off. Pressing the menu or input button does nothing.
I fear it could be the main board. What are your suggestions?
Just hold down the input button on the right side of the tv. This is the bottom one. So,
With the tv off,
press and hold the bottom button (input)
when the tv turns on, and you see the input menu
release and press the button to put the tv into a mode that works!
Thanks
AWESOME!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Saved me from buying a new TV!!!!!!!!!!!!!!!!!!!!!!!!!! THANK YOU THANK YOU THANK YOU !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Solution 3 worked for me. TV off, hold down the Input button on the remote until the TV powers on. Continue to hold the Input button down and move off of the RGB input using the up/down arrows. Thanks!
The way I fixed this issue is as soon as I turned on the TV I immediately began switching sources. It worked!
THANK U! THAT WAS ABOUT TO GET ME INTO TROUBLE! IM SO GLAD U R ON THE WEB FOR DUMMIES.
hit the RGB on the remote and ended up at this site. To correct, I pressed and held in the input button on the TV when powering on. I previously tried holding down the input button on the remote when powering up, that approach did nothing
Lycan2, thanks for the help!!! I called Vizio and had me a bunch of things and recommended a repair service call. Did what you recomeended and it worked!!
Awesome fix. I was thinking I would have to buy my Grandma a new tv for a minute. Fixed!!
I tried everything even calling techs at vizio. They said new board. Then I found this site, WORKED the first time . Thanks
Your welcome
Lycan2 U R THE BOMB..... THANK U VERY MUCH.....
Thanks! That worked!
I have a Vizio Smart tv and when I'm watching Netflix sometimes it says no signal will turn off soon but the tv is on and Netflix is going idk y it does this?
What device are you using for the Netflix? The smart Vizio only, or through a device like tiger stream or and Xbox One?
FIXED: FIXED: Problems with vizio e472vl no signal on antenna input? THANKS EVERYONE!!! I don't know which one FIXED my CABLE/ANTENNA input problem because it wouldn't detect ANYTHING I screwed in, antenna, VCR cable, ETC., for about a week 2/3/2019 when my cousin gave me? this AWESOME SMART TV!!! But last night ?? !? I had a chance to do EVERYTHING I FOUND on this site, TURNED it off because I was too tired and someone here had mentioned they left it alone over night AND WALLA, this morning it scanned in 3 channels ABC 7.1-7.3!!! I'll take it?!!! Now I know the input is not broken!!!??????
FIX FOR THE BLUESCREEN NO SIGNAL PROBLEM: without powering the TV on, hold down the input button and it will reset the signal :) you should see the TV power itself on once it resets... hope this helps.
Joe
Plug in the TV. Do not turn it on. Just press and hold the input button on the side...it will turn on by itself !! Then choose the correct input AWESOME!!
Thanks so much ! This fixed my tv
Thanks so much...I thought I was going to have to buy a new TV...I had tried unplugging and plugging back in all connections and nothing worked! Last minute thought I would search Internet ...thank you so very much for your helpful information!!
For me ...
To Fix VIZIO ... No Signal .... Problem
Because it is stuck in RGB mode
TV turn on said ... " No Signal " ... the turn off in 3 sec.
..... When TV OFF ...
Hold Down 2 Buttons .... MENU + INPUT ....
Power will ON ... Change INPUT quickly within 3 Sec.
.... to HDMI or Others ... TV will work as normal ... !!!
I tried all of this but it keeps stating "No Signal" Any other suggestions?
I just 10 minutes ago got done solving this problem. All together, I spent about an hour before I got it to work. A blue screen would come up with "no signal" indicated and then the tv would power off after 2 or 3 seconds. I first called vizio tech sup. and they weren't able to fix it. According to the ts guy, this happens when you press "input rgb" and don't have a computer attached to the tv. That's possible in my case because I was trying different inputs off my Harmony remote when it happened. I'm not sure which process finally fixed it, but the following are the steps I used, not necessarily in order.
--Unplug tv for 2-5 minutes. Plug back in.
--Turn tv on using remote. When it comes on, press and release "input" button several times.
--Same as above, but use buttons on side of tv.
--Turn tv on. When it comes on, press and release the input option you use to watch tv.
--When a box appears showing several input options, select the one you use to watch tv.
GOOD LUCK!
P.S.--DON'T PRESS THE "INPUT RGB" BUTTON IF YOU'RE NOT HOOKED UP TO A COMPUTER!
I tried for about 45 minutes, couldn't figure this out! Finally, I called my husband into our bedroom, then he too began pushing the buttons. Then I said , let me google this. Low and behold, It directed me to your site. I did exactly as "seemo" suggested, it worked! Thanks so much!
Thank you!!! Seemo's solution worked!!! Love this site!!!!!!
For My VIZIO
My wife was bitchin and complaining about the no signal and blue screen and was about to throw the Vizio tv away. I told her to get off ur *** and hold the input button down and Poooof the TV came back on.. Now she gotta give me suckie tonight..Score!
Hold the "INPUT" button on the remote down while simultaneously pressing the
"POWER ON/OFF" button manually. This defeats the timer.
This is most likely a temporary solution, so please check with your warranty carrier.
Best wishes!
J & S
oh! hold the power button on the television, not the remote! thanks
For My VIZIO
Power will ON ...
On my Vizio TV there is a button on the bottom left side which I don't know what that is for, is that the input button or the power on button? When I press it the no signal message comes back on
Solution #4 got me on the right track: this is what I did to get my Vizio (42inch LCD) TV back from oblivion:
1. disconnected tv for about 5 minutes
2. turned tv on, and then HELD the "input" button pressed in for about 10 seconds without letting go. NOTE: the tv turned off as it had for days, during these 10 seconds, but....
3. The tv turned itself back on!
4. Now it's a matter of finding the right input; for me it's the "TV" input that has the signal.
--Good luck, and thanks to those that posted on this irritating issue, it saved me a bundle of cash and headaches.
I have the 32" version. Pressing input alone did not work for me. It never turned itself on. I help it forever. Then I press "on" on the remote while holding the "input" button on the TV, and that worked right away.
I got the same problem and solved it. Basically the "RGB" Input is tripped.
To solve this, you will need a computer with a serial port and RS 232 serial cable (to connect the TV RGB port and the computer).
1. Connect the computer to the TV RGB port (located in the rear panel connections) using the RS 232 serial cable.
2. Turn On the computer.
3. When the computer has powered up (you see the computer desktop), turn on the TV and before the it turns off, set the computer in Presentation Mode (you will be able to see the computer desktop on the TV screen).
4. The TV now does not turn off and you will be able to use the remote control to set the Input mode in "TV".
Hope this fix your problem.
I had this problem on my Vizio VO22L. It was giving me a "No RGB Signal" "The Power Will Be Turned Off" message when I had it in RGB mode (with VGA input from my PC). Anytime I left my PC on and turned off, then turned on the power of this unit, I got this message. I just got off the phone with a very friendly and patient Tech Support woman at Vizio, who talked to several different techs who all came up multiple things that didn't work or help. Finally, while we were talking, she came up with the idea of going into the settings menu and doing a "System Reset" to see what happens. What do you know, it worked!
To anyone else having this problem, try this. With the PC and TV on, in RGB mode, go into the menu screen with the remote (could also be done in TV mode). The far right tab is "Setup". Use the arrow keys to go down to the "System Reset" option. When prompted "are you sure" select "Yes". I powered the monitor off and on, and the problem is gone. Now if it happens again, I know what to do.
Thanks for this fix. Saved me from having to buy a new tv...my husband was out the door to go get one when I found this on-line. Blue screen no signal two days multiple phone calls to vizio and cable company no help. Thank you all.
I tried unplugging the power for several minutes as well as swapping inputs, including from a laptop. Solution #3 is actually what worked. It is as easy as pressing the input button on the side of the TV. When the set clicked on, the familiar input menu was there in place of the blue "no signal" screen.
I had the same problem. I bought my VA26L at Sam's Club marked "Coaxial doesn't work" for $164.00. After reading this blog, I tried holding the "Input" button with no success. I then went into the menu and had the TV scan for channels. It found the channels on my antenna and took off. Hope this helps someone else. Thanks.
Turn on everything.
press the FN BUTTON AND F7( LCD) ON UR LAPTOP.
THEN FROM THERE, U WILL SEE UR OPTIONS.
IT WORKED FOR ME.
HOPE THIS HELPS.
I have my Vizio hooked to cable box, and I get "no signal" blue screen, too. I got help via Verizon and cable co. IF you have yours connected to cable when the "no" comes on, take the power cord out of the back of cable box, wait about a minute and re plug. The cable box will display an odd bunch of lines where the time and channel are displayed on front, it's working on reconnection. It should re -program itself, but if not, just turn cable box off with remote and then back on. The cable pic should appear again. This helped my "no signal" problem when I was just trying to watch cable and it wouldn't show. Good luck.
It Works THANK YOU VERY MUCH JOHN
This tv is a piece of sheet, the blue screen probelm is not solvable and happens all the time. no tv for me today, glad i spent all that money.
For My VIZIO
Power will ON ...
You should try resetting your TV back to factory reset. Press down the mute, 1, 8, 2 and power on using the remote.
Wow... it worked for me, too.. the technician i spoke with said some blah-blah module was burned out and that may have affected the blah-blah converter. "I Just saved a bundle on my TV repair."
My vizio brought up blue screen saying HDMI no longer ??? then some letters lxsoloxys??? then press exit . now tv black screen and nothing coming up. plzzz help
Had the same problem after screwing around with the "New" remote the Vizio GV42L went to "No signal" and shut off. I went to bed sick to my stomach,when I woke up I came to this site,got the info and I tried the Hold the input button while the TV is off and it worked again...thank you guys and Fix Ya for the help!!!!
Ok i was watching a dvd in the dvd player i turned it off then swiched to tv i saw a pic then it went to blue screen no signal wtf? did i do plzz help ty
Great site! My husband thought we were going to have to choke up more money to buy a new tv on Christmas! We connected the tv to our laptop with the RGB cable and changed the input. My 3 yr old had pressed the RGB input when he was trying to be helpful and turn off the tv. Thanks again for the suggestions.
That works for me too should i get ready to git rid of?????
L42HDTV10A
I have the same problem. Blue screen comes up & says no signal & it cuts itself off before I can get the menu button on as the tech ask & I have done this repeadedly.
No signal. Turns itself off immediately.
same exact problem as above...
Same problem with blue screen - no signal - push input button numerous times and it tv shuts off in a couple of seconds. no response at all from tv.
have the same no signal problem. please notify!
I turn the Vizio on, blue screen with No Signal. Then turns off. Was working beautifully until yesterday.
no signal, same issue as others. Is the cable box the problem?
Same problem as anyone else...regretting buying the Visio.
I hit TV - power button. Get a blue screen with a "no Signal" comment Also shows 401 KXLY HD Cable in the upper left hand corner. I've pushed way too many buttons . . . how can I turn my TV on???
HELP!!!
Same problem RGB input was pressed now can't get it on longer than 5 seconds to change the input setting!
Same thing. Turn it on, no matter what button you push, it just say's 'no signal' top center, then shuts itself off. This SUCKS
Same thing. Turn it on, no matter what button you push, it just say's 'no signal' top center, then shuts itself off. Please help!!
I have a 55 inch LCD Vizio with the same problem. I am not even using the tv, only hooking up to a DVD player, and can not escape the no signal message.
It will walk me thru setup, then force me to take two choices cable or antenna.
There is no 3rd option of DVD only. How do I get out of this no signal mode and get to have the DVD work and play movies?
I have the exact same problem started last Wednesday 2/4/09. On 2/5 morning, I called Vizio Tech Support and the guy tried but was not able to help me resolving the problem. He referred me to ITI repair company for out-or warranty repair. I called them right away but they just took my number and said they'll call me back. They call me the next (2/6) morning, and the guy just asked me some detailed questions of the problem and said they'll call me later (don't know when) to let me know the cost and time.
I decided to look for possible solutions on internet, and found this thread. I tried the recommended solution (when TV is off, press and hold the "Input" button...) after I returned home. IT WORKS! Problem solved. I have my 3 year old 42" Vizio TV back!
Thank you so much FixYa!
A New Happy Camper,
Ted
Hey Ted your the man! Hold down the input button and it works! Thanks to Ted and FIxYa
solution number 4 worked for me in 10 minutes. i unplugged set and followed directions of pressing input from remote. i had tried for 4 hours before i came upon this site. thanks so much!! this was more than helpful. it restored my sanity, because it was driving me nuts!! my tv is 32" vizio and i had pressed the rgb on the remote by accident.
I have the same problem, it only happens when we switch HMDI input from DVD to Sat. I tried to hold down the INPUT button, but that didn't seem to work. Maybe I didn't hold it long enough. Anyway, I got my TV back by hooking my laptop to the RGB signal input port with an external cable. I had to be sure the laptop was outputting to external monitor. Then, when I turned on the Vizio, I got a signal (from the computer) that enabled the set to stay on long enough for me to use the HDMI button on the remote to switch to the Satellite and I was okay.
holding the reset button on the tv worked!!! THANKS GUYS!!!
Thanks for this fix. I was playing with the remote, wife happened to be setting next to me, when the tv shut off automatically. She wanted to fix it ASAP. You guys saved me from sleeping on the couch. Holding the input button down fixed issue. Apparently I had pressed the RGB inupt. Great site.
Just had the same problem. By pressing "input" button on remote tv powered on and showed input menu. Had to then quickly push "input" on side of tv to toggle back to HDMI becuase theres a delay before remote begins to control tv. Thanks guys, thought my baby was toast.
My 5 year old 42" Vizio would give me the "No Signal" message on the blue screen on power up, and then shut itself off after 3 secs, before I could get into the input menu. Powering it up by holding down the "Input" button on the TV, which brought up the input list, worked! I was able to switch it to a live input, and all is good...
VIZIO 37" TURNS ON - SAYS NO SIGNAL - AND THE OFF CUANDO SUCEDE ESTO ES QUE EL TELEVISOR ESTA PUESTO EN EL MODO RGB. SOLUCION 1- APAGAR EL TELEVISOR. 2- UNA VEZ APAGADO, EN UNO DE LOS LADOS DE LA PANTALLA O MONITOR DEL TELEVISOR ENCONTRARAS LOS SIGUIENTES BOTONES: POWER MENU CHANNEL VOLUME INPUT 3-VAS A MANTENER OPRIMIDO (LOS DOS A LA VEZ) EL BOTON DE ENCENDIDO (POWER) Y EL DE INPUT (ALREDEDOR DE 30 SEGUNDOS) HASTA QUE SALGA EN LA PANTALLA UN CUADRO QUE DICE MAIN (MENU). EN ESTE CUADRO APARECERA LO SIGUIENTE: TV AV1 AV2 COMPONENT 1 COMPONENT 2 HDMI 1 HDMI 2 3-TAN PRONTO SALGA, LO MAS RAPIDO QUE PUEDAS, VUELVES A OPRIMIR EL BOTON DE INPUT PARA SELECCIONAR OTRA ENTRADA O MODO DE VER EL TELEVISOR. 4- SI NO LO OPRIMES RAPIDAMENTE, EL TV SE APAGARA NUEVAMENTE. VUELVE A REPETIR EL PASO NUMERO 3, HASTA QUE PUEDAS SELECCIONAR OTRO MODO DE VER EL TELEVISOR QUE APARECE EN EL CUADRO. (TV, AV1, AV2, COMPONENT 1, COMPONENT 2, HDMI1, HDMI 2) 4-UNA VEZ SELECCIONAS OTRO MODO DE VER EL TELEVISOR, SALDRA DEL MODO RGB Y LA TV VOLVERA A FUNCIONAR COMO ANTES. TRATA DE HACERLO, FUNCIONA.
VIZIO 37 "TURNS ON - SAYS NO SIGNAL - AND THE OFF When this happens is that the TV is set to RGB mode. SOLUTION 1 - off the TV. 2 - Once off, in one side of the screen or TV monitor will find the following buttons: Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â POWER Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â MENU Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â CHANNEL Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â VOLUME Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â INPUT 3-GOING TO KEEP PRESSED (both at once) the power button (POWER) AND input (about 30 seconds) until it comes out on the screen a box that says MAIN (MENU). IN THIS PICTURE shows: Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â TV Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â AV1 Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â AV2 Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â COMPONENT 1 Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â COMPONENT 2 Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â HDMI 1 Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â HDMI 2 3-OUT SOON, as fast as you can, go back to pressing the INPUT button to select another input mode or watch TV. 4 - IF NOT oppress quickly, the TV will turn off AGAIN. Repeats step 3 until you can select another interrupt viewing LISTED IN TABLE. (TV, AV1, AV2, COMPONENT 1 COMPONENT 2, HDMI1, HDMI 2) 4-LOGRES SELECT ONCE otherwise the TV will exit TV RGB mode and return to work as before. Try to do it, it works.
This worked like a charm. thank you!
fairly new tv turned on last night wont turn on today
For My VIZIO
Power will ON ...
Nikk Carter, thanks for the advice. My 47" Vizio is back on....thanks to you!!
Nikki is a genius. I was already thinking of buying another tv
