Power locks not working either by remote or door inside locks. They recently stopped working last week. At first the left passenger side stopped and now none of the locks lock or unlock without manual action.
Solution: Elect lock activator inside door either weak or is binding not pulling lock all the ... Right passenger door wouldn't open from outside, then my kid turned on the interior ... civic door won t open from inside or outside fix no drilling ... Has recently started to just suddenly lose power and stop but i can start it again and it ...
Tesla MotorsFor some reason, the passenger side front door will not open when pulling on the handle. We have the tech ... There's nothing you can do to fix it yourself. ... I tried locking and unlocking it at the restaurant and that didn't work so I just opened it from the inside. ... Handles extend, lights work, but I can't open from the outside.
Sounds like the rod that goes from the lock to the key came off. There is usually a little plastic clip that holds it together and they break and you get what you are experiencing. You have to take the inside panel off of the door to get inside it.
The only time my doors don't lock with the remote is when a door is open. If your problem is mechanical it wouldn't unlock. Might be a sensor thinking a door is open. Does the other functions with the remote work like rolling the windows down or hitting the lock button flashes the light ? I can't lock my doors from the inside with the remote.
have you tried locking from the passenger side switch? alot of times if a window is left down during the rain, water will run in on drivers side and right down into the power window and lock switch causing it to corrode inside over time.
You'll need to replace the solenoid (motor) that doesn't work. Not hard once you get the door panel off. I suggest you buy the correct part, not a universal one.
hi there you say you have had the lock changed do you mean the key hole or the door closure part of the lock?
if you changed the key part its the main lock that's faulty and the reveres is true ,
if the remote is working on one door it is not the remote that's the problem.
i hope that this has been helpful regards John
make sure than you have not split any fluids on the passenger front door most of the times is where the module to control the windows and doors is located, try by unpluging the batterie and the after a minute plug it back and see what happend but if any of your ft doors have been split with liquid or rain has gone inside then most likelly the module got moisture and not working
