Question about Intel Play QX3 Monocular Microscope
Need qx3 drivers for windows 7 64 bit
Need qx3 microscope drivers for windows 7 64 bit
    Sniper:
  • 72 Answers
The Intel QX3 is not compatible with 64 bit operating systems. It will not work. Sorry.
You can either reinstall Windows 7 as a 32-bit version or purchase a QX5 model which is compatible with Windows 7 64-bit.
-Mark
Posted on Jul 04, 2011
    New Friend:
    Problem Solver:
  • 10 Answers
Activate windows 7 ultimate product key
I suggest you click here: www.fastbackorders.com
My windows activator here and activation successful.
Posted on Sep 21, 2015
6ya staff
SOURCE:
I have the Digital blue Microscope QX5 and need to load the driver for the windows 2007 64 bit. The download link on didital blues website does not work. any siuggestions
Sorry, but there are no 64-bit drivers for the QX3. You need to find a Windows 7 system running the 32-bit operating system. The instructions for installing the QX3 with 32-bit Windows is document on this site.
-Mark
Dec 23, 2014 | Digital Blue Science & Laboratory
I need dowland drivers to intel play model APB 24221 99A
Here are the instruction for installing the QX3 (or QX3+) Microscope with Vista and Windows 7. You must be using a 32-BIT VERSION. The QX3 is not compatible with 64-bit versions.
Note, DO NOT use the software from the CD that came with the microscope.
DO NOT plug in the QX3 microscope until Step 4.
Step 1. Download and install the QX3PLUS.EXE software from Intel:
http://tinyurl.com/QX3-Win7-Files
Step 2. Download and install the QCODINSTL.EXE software from:
Step 3. Download and extract the QX3 Drivers from:
Step 4. Now, plug in the microscope.
When the "Found New Hardware" wizard appears you will see a message saying that the driver installation was not successful. Click the Close box. You need to install the driver manually by following these steps:
a. Click START - Select Devices & Printers
b. Right-click on the Intel QX3 Icon and select Properties
c. Click the Hardware tab - click Properties
d. Click Update Driver - select "Browse my computer for driver software"
e. Browse to the folder with the extracted QX3 drivers from Step 3. above. The driver software should install successfully.
Before you run the QX3Plus program right click the icon, click on "Properties", click the "Compatibility" tab, check the box next to "Run this program in compatibility mode for:", then choose in the drop-down box "Windows 98 / Windows ME". You should also check "Run as Administrator" if your account is a "Standard user".
Step 5. Now double-click on the QX3+ icon on the desktop and the program should run.
Aug 13, 2014 | Intel Play QX3 Monocular Microscope
Qx3 microscope driver for Windows 8
Here are the instruction for installing the QX3 (or QX3+) Microscope with Windows 8 and Windows 8.1. You must be using a 32-BIT VERSION of Windows 8 or 8.1.
Note: The QX3 is not compatible with 64-bit versions of XP, Vista, Windows 7 or 8.
Step 1. Download and run the QX3plus.exe program from:
http://tinyurl.com/QX3-Win8-1
After the program installs, uncheck "I would like to view the README file." Click "Finish".
Step 2. Download and run the qcodinstl.exe program from:
If asked about NTVDM, click "Install this feature" then click "Close"
Step 3. Download IntelQX3driverXP.zip and save (do not open) the file from:
Step 4. Now, plug in the microscope. The driver should load silently.
If the "Found New Hardware" wizard appears and you get a message saying that the driver installation was not successful. Click the Close box. You need to install the driver manually by following these steps:
a. Right-click START - Select "Device Manager"
b. Right-click on the Intel QX3 Icon and select "Update Driver Software", select "Browse my computer for driver software"
e. Browse to the Download folder with the extracted QX3 drivers from Step 3. above. The driver software should install successfully.
IMPORTANT: Before you run the QX3Plus program for the first time, right click the "Intel Play QX3 Microscope" icon on the desktop, click "Properties", click the "Compatibility" tab, check the box next to "Run this program in compatibility mode for:", then choose "Windows 98 / Windows ME" in the drop-down box. You should also check "Run as Administrator" if your account is a "Standard user". Click "Apply" then "Ok".
Step 5. Finally, double-click the "Intel Play QX3 Microscope" icon on the desktop and the program should run.
If you get a message that the microscope is not plugged in, quit and restart the program.
If the program hangs or crashes, reboot the computer, then restart the program.
Comments and suggestions to mmehall [at] yahoo.com
Apr 05, 2014 | Intel Play QX3 Monocular Microscope
Windows 7 driver
Step 1. Download and install the QX3PLUS.EXE software from:
Jan 19, 2014 | Intel Play QX3 Monocular Microscope
QX3 microscope
Dec 30, 2013 | Intel Play QX3 Monocular Microscope
Digital blue qx3 drivers
Here are the instruction for installing the Intel QX3 (or Digital Blue QX3+) Microscope with Windows 7 or Windows 8.1. You must be using a 32-BIT VERSION of Windows 7 or 8.1.
Aug 20, 2013 | Intel Play QX3 Monocular Microscope
May 02, 2013 | Intel Play QX3 Monocular Microscope
I was given QX3, not QX5 software with instructions in German. My computer is windows 7. should I still install the two intel play disks which came with the computer microscope. Can I install it as...
Mar 26, 2013 | Intel Play QX3 Monocular Microscope
Now I use the win7 64bit home system,and I had qx3,where can I find the driver?or may I use the driver for windows xp to use?
-Mark
May 22, 2011 | Intel Play QX3 Monocular Microscope
The software keys into the integrated webcam instead of the qx3 microscope! Need the proper driver software for windows 7 Device Intel Play Qx3 monocular microscope
Here are the instruction for installing the Intel QX3 (or QX3+) Microscope with Windows 7. You must be using a 32-BIT VERSION. The QX3 is not compatible with 64-bit versions of Windows 7 or Vista.
Before you run the programs below, right click the icon, click on "Properties", click the "Compatibility" tab, check the box next to "Run this program in compatibility mode for:", then choose in the drop-down box "Windows 98 / Windows ME". You should also check "Run as Administrator" if your account is a "Standard user".
http://tinyurl.com/qx3plus or
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&Inst=Yes&ProductID=160&DwnldID=4419&strOSs=All&OSFullName=All%20Operating%20Systems〈=eng
http://tinyurl.com/QCODINSTL or
http://downloadcenter.intel.com/Detail_Desc.aspx?strState=LIVE&ProductID=160&DwnldID=2089&agr=N&lang=eng&PrdMap=160
http://tinyurl.com/IntelQX3driverXP or
http://hyperslug.s3.amazonaws.com/IntelQX3driverXP.zip
Double-click on the QX3+ icon on the desktop and the program should run.
Aug 21, 2010 | Intel Play QX3 Monocular Microscope
Intel Play QX3 Monocular Microscope Logo
4,395 people viewed this question
Top Intel Science & Laboratory Experts
Pokinhas
Tom Chichester
Are you an Intel Science and Laboratory Expert? Answer questions, earn points and help others
