SOURCE: How does one remove a
twist the collar around where the blade fits in the saw. It will lock in the open position. When you insert the new blade, do so firmly until the collar releases locking the new blade in place. Give a tug at the blade to make sure it is locked in.
SOURCE: rs20 bosch case falling apart
If you loosen the screws at the end of the saw that hold the boot on you can carefully snip the the rubber around the holes. This will alow you to remove the boot without dismantling the front of the saw. The boot is glued and they are sometimes difficult to remove.You can carefully take a flat blade screwdriver to peal the boot off and re-use it. Hope this helps
