Hi. Thanks for your help. I have a Weller model 8200. I need a manuel for it and I need to buy a new 'tip' for it. Please let me know where I can download a manual for this ad get a new tip. Thanks.
There are normally three of the same type. They are consumable, you don't need to stock all the different types - just buy the one you need for your current project.
Note, these are high power and were commonly used for soldering wires in the point-to-point wiring used in old tube electronics. Do not use this on a Printed circuit board - it will damage any silicon component.
Use a a soldering pencil for printed circuit boards.
Hello, your Weller 8200 soldering gun is rated at 140 or 160/100 watts. While the junior was about 70 watts. Go to this web site for parts: www.e-sonic.com/aboutus/cat/S/soldering%206.pdf GB...stewbison
The tip screws are a drilled bolt for this unit. There isn't room to tap the barrel holes out further if the threads are bad. You used to be able to buy tips that were pre-loaded with the proper clamp bolts. Good luck!
The body contains a transformer, which steps your 120AC down to a lower voltage. The lower voltage runs THROUGH the tip, heating it up. Possibility ONE: Transformer is no good, throw it away. TWO: Not enough current is running through tip, because tip is corroded OR those mounting nuts are corroded, loose, OR somebody put new tip into nuts but neglected to bend both legs of new tip 90 degrees. Look at the barrels, you will see little holes in the sides, tip's legs go into those holes.
