Garden Logo
A
Anonymous Posted on Jun 16, 2010
My gts Toro mower Model 20070 will not start with the electric start. If you reposition the blade you can then give it an extemely hard pull it will start. How can I make it easier to start so I can use the electric start?
Mike Squire
Level 3:
  • Master 420 Answers
  • Posted on Jun 16, 2010
Mike Squire
Master
Level 3:
Answers
420
Questions
Helped
258382
Points
1000
Try this; take the air cleaner element out and squirt some light oil (like WD40) into the carb and immediately try the starter, if the engine starts right up it likely needs new rings.
Toro Model 20070 lawn mower starts and runs, just does not seam to have a lot pf power does anyone have a lack of power issue with their Toro 20070 Pace Lawn mower. Runs fine just no balls
could be dirt in the carby , blocked fuel filter or lack of adjustment in the accelerator cable
I will go for a cable adjustment as they slip under the clamp on the carby bracket when the throttle is pull wide open
I own a Toro model 20070 mower with a Tecumseh engine. It's 8 yrs old. I have regular maintenance conducted. The mower starts and runs well but about 20 minutes into mowing, when I shut it down to empty...
Are you sure there is oil in the machine?
Are the Fins on the engine clean and not loaded up with sand and mud?
Sounds like it is running so hot that it is seizing.
Aug 06, 2014 • Toro Garden
1helpful
Why won't my toro 6.5 gts start after taking blade offand replaceing it?
From flipping the mower on it's side the top of the cylinder gets slightly flooded with crankcase oil. A good priming and a few extra pulls on the starter cord is usually necessary after this type of maintenance. You'll see a few extra puff of oil smoke upon starting. This burns off in less than a minute.
Toro gts 6.75
you will probably need to replace the tabs that pop and grab the fywheel, the springs should be replaced as well.
Jun 15, 2013 • Garden
3helpful
TORO Model 20016 6.5 hp GTS Engine pull cord is stuck and won't pull out more than 5 inches
Did you check under the deck for clogs? If its not clogged, DISCONNECT the spark plug wire, and try to turn the blade by hand... Oh yeah, did I mention DISCONNECT the sparkplug wire FIRST! If the blade won't budge, you might have a seized engine. If the blade does move, the problem is in the starter recoil. Rewind the starter string, and check the spring for damage. Good luck!
I have a Toro Model 20070 Electric start Lawn mower. It will not start. I changed the plug and filter. I pulled the plug and there appears to be no spark. When I turned it over I saw no spark. I guess my...
check your mower for interlock switches that might interupt spark for safety reasons.
A chute switch or something like that. Check your owners manual for troubleshooting.
Unplug the keyswitch and try pull starting to rule out a bad switch.
If it still doesnt have spark you might need a new coil.
The coil is right under the recoil cover and are fairly cheap.
A set of hand tools and $30-50 for the part should do it.
Good luck and be careful.
I have a Toro 20070 and it won't start. Doesn't seem to be engine but more in the pull rope. I engage the bar and the recoil pull stare seems locked. Suggestions?
there is a flywheel brake on them, possibly a malfunction there you will have to pull the top shroud off and see if maybe cable broke, that attatches to the brake which when you engage it so the eng. can rollover with pull start.It is a safety deal so that when you let go of handle the blade stops imediatly, Hope this helps
Apr 23, 2011 • Toro Garden
Mulching blade replacement for Toro GTS 6HP
goto toro website and use model of machine to get blade model and use blade model in google to get prices and then order them
Jul 06, 2009 • Garden
1helpful
2answers
Top Garden Experts
Jay Finke
Jay Finke
john h
