SOURCE: No Cold Air
Have you removed inside filters and cleaned them? have you gone up and removed the cover to see if fins are dirty, or perhaps wasps etc. Does fan only have one speed on thermostat. Does fan run faster on fan only operation? Is it tripping your breaker at all?
SOURCE: I have an 89 executive motorhome with a duo-therm
Hi! I had an 89 executive and have some spare
parts
SOURCE: installing rv roof airconditioner heat strip
I see what you see also in the manual. The difference is the Heat Strip package that part is optional and the 600212-001 with the optional heat strips becomes the new 600315-001 I talked to Dometic Duo-Therm and the models are the same but they both are not heat pumps but the new heat strip package comes on when told to go into heat mode when you change the thermostat to heat. The part you purchased will fit both model numbers you listed for your roof top air conditioner. Thanks, Sea Breeze
SOURCE: The Duo-Therm AC in the motorhome has started
More than likely water is pooling on top of the rv and leaking thru a crack next to the unit. The other problem would be the drain hole is plugged you will have to remove the top to ck. good luck
SOURCE: Resently bought a replacement blower
if you have not got your answer yet, send to me as an attachment [email protected].
Testimonial: "Mark is a good man."
