Amana PTH123B35AJ Air Conditioner Logo
Posted on Jun 15, 2010
Hello. I have an Amana 15,500 btu AC and I need to know where to purchase the filter for it
WatsHVAC
Level 1:
Loyalty:
Visited the website for 30 consecutive days.
  • Contributor 35 Answers
  • Posted on Jun 15, 2010
WatsHVAC
Contributor
Level 1:
Loyalty:
Answers
35
Questions
0
Helped
53388
Points
87
Try Valley of the Sun. They generally have parts and accessories for most Amana units.
http://www.valleyofsun.com/
Armana APN14K-E portable AC freezes up
Lack of air flow or a lack of refrigerant are the two primary reasons why coils freeze. Clean the filter and the coil, if frost continues it is likely low on refrigerant.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Amana ASD2522WRS01, Do it have water filter and where?
Yes your refrigerator does have a water filter,its located on the front grill/kickplate below the freezer door. The part number for it is 4396841 it could be purchased at your local appliance partstore or online at;
apdepot.com
partselect.com
apwagner.com
repairclinic.com
applinacepartspros.com
This youtube video will show ya how to replace it http://www.youtube.com/watch?v=lTVfbVkEINI
GENE
I do not know how to set the air conditioner (Amana ACC085R) for lower temperatures. I want it to go to 70 when it's reading 78. Thank you. Also, I have cleaned the filter and coils so that's...
you might try unpluggging hte unit for a munite and plugging it back in to see if it resets. close all unused rooms on really hot days like we are having. clean the filter as well Hope this helps
I have a 1400 btu portable air conditioner ( AMANA ) and the fan is broken, how to replace it.
Obviously, you will have to disassemble part of the cabinet to access the fan blade. Removig the blade should not be difficult. If it's the fan motor, than that may be a challenge. However, since you did not furnish the Model Number of your AC Unit, there's not much more I can tell you, other than where to find the part(s) you'll need. Try Factory Appliance Parts http://www.appliancefactoryparts.com/airconditioners/amana/amana-motors-and-blades.html You'll definitely need the correct Model Number of your unit, to search for the part(s) you'll need.
Hope this helped you.
My Amana AC won't cool. Only the fan blows, the condenser is not kicking on. Breaker has been reset 16 seer unit. I have had nothing but problems with this unit since purchasing 6 months ago. My electric...
Hello. first thing to check is if you are getting 24 volts to the contactor coil, if not then the low voltage wiring needs to be checkd, if you are getting 24 volts to the contactor then and it is not energizing it must be replaced. Let me know what you find
AC unit LWHD 1800R won't turn on & test/reset does not respond.
Reverse the wires in the receptacle ,not the ground,this is most likely the problem the way the circuit is set up in the ac unit.Let me know if this helps.
Hello, the exclamation point light is blinking on my free standing amana ac. I've drained the water and cleaned the back filter. aby other suggestions?
Try disconnecting power for 5 to 10 min to reset the unit.
If the light comes back on let me know and locate your owners manual for refference.
2helpful
Hello i got a AMANA 9,000 BTU and the light its blinking of the triangle and i lost the manual of the AC can you tell me what can i do i cant turn on my ac
I have the Maytag version of this machine and the blinking triangle light means the water tray is full. The machine won't operate until that water has been drained -it's the little black tube with the plug at the bottom behind the machine. Pull the plug, tip it down (preferably with a shallow pan underneath to catch the water) and drain as much as you can. Once you've done this, put the plug back in and it should start.
Outside unit freezing over
check the outside drain in the pan if there is a plug in the bottom pull it out.the ptac unit will go into emergency heat and run more the colder it gets outside
Top Amana Heating & Cooling Experts
Mike Cairns
Mike Cairns
Jay Finke
Jay Finke
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
