Swisher Zt2560 Zero Turn Radius 60" Riding Mower Logo
Posted on Jun 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What kind of hydraulic oil does swisher zero turn mowers yous
johnny rebel
Level 3:
Top Expert:
  • Swisher Master 10,875 Answers
  • Posted on Jun 02, 2015
 johnny rebel
Swisher Master
Level 3:
Top Expert:
Answers
10875
Questions
0
Helped
2937685
Points
47944
5 Related Answers
Anonymous
  • 157 Answers
  • Posted on Oct 26, 2009
SOURCE: I have a Grasshopper zero turn mower that uses
yes just reguler hydralic oil it wont hurt a thing. but dont use atf its for transmissions in vehicles
Anonymous
  • 623 Answers
  • Posted on May 26, 2010
SOURCE: best way to change hydraulic oil in zero turn
I don't understand why you want to change, it is a closed system, so no contamination can get in. Anyway, there should be a small tank somewhere where the hydraulic oil is checked. You can siphon the oil out of there with a oil suction gun or turkey baster, and replace it with new fresh oil.
Do you have a reason why you think the oil is contaminated or has been overheated? It is quite a rugged oil meant to stand up to brutal environmental conditions like continuous use in high heat, and in plow trucks operating in extreme cold with continuous duty.
Anonymous
  • 32 Answers
  • Posted on Jun 21, 2009
SOURCE: John Deere F620 zero turn mower
you probably have the belt on wrong, check your manual to see if you have it on right.
Anonymous
  • 64 Answers
  • Posted on Aug 23, 2009
SOURCE: TORO Z5000 zero turn mower. right side
it should hold hydralic fluid there should be a resirvour somewhere on the back along with the pump you should be able to check the level there and if you don't get the leak stopped it will lock up the whole drive system.
Anonymous
  • 62 Answers
  • Posted on Oct 27, 2009
SOURCE: Snapper Yard cruiser zero turn hydro pumps
should be on dip stick other wise use 90 wght wont hurt anything
Can hydro oil be changed and what type oil on Swisher ZT2460 mower?
yes hydro oil can be changed and should be at regular intervals, the manual should tell you how often and the type of oil to use for best lifespan.
good luck.
What kind of hydraulic oil does a Woods 6200 zero turn mower, kohler engine take
10w30... And I use ONLY Kohler 10w30 in my customers Kohler engines.
Now the hydraulic system in the Woods mower most likely uses a 20w50 MOTOR OIL but it's been about 5 years since I have even seen a Woods unit. www.woodsequipment.com
Oct 20, 2013 • Garden
What kind of hydraulic oil for woods 6200 zero turn mower?
There should be a label on the mower that lists the recommended hydraulic oil to use. I could not find the exact oil type for your model, but the label should be on the back of the mower.
If you are unable to locate the label, contact Woods support here:
http://www.woodsequipment.com/manualRequestForm.aspx
White Horse Zero Radius 54" deck. Transmission stopped working while cutting the lawn. No response on levers. PTO and deck work fine. Just won't move...
check that the drive pulley to the hydraulic unit is still fixed to he shaft and has not got loose and just turning but not driving the pump shaft. Other than that you may have to check out the pump pressure of the drive unit.
Wiring diagram for 1958 Swisher Ride King Riding Mower
need wiring diagram for 1958 swisher ride king riding mower. need picture of mower
How do you change the oil in a ZT2560 Swisher mower?
the drain plug is under the starter when removing the plug make sure to drain the oil into a pan. after it's finished draing replace the plug and refill with the proper grade of oil start with a 1/4 quart of oil and check the level on the dipstick. if still low keep adding ( little at a time) until it reaches the full mark on the dipstick...good luck
We need a photo of how the hydraulic belt goes on our mower. We lost our manual.
It should be fairly simple,if you remember always put the V of the belt into V pulleys and the back of the belt on flat or idler pulleys. Its fairly easy to figure out. I didn't find a diagram of the belt system that runs the hydraulic pump. I hope this helps some.
Top Swisher Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Swisher Garden Expert? Answer questions, earn points and help others
