Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
I had to rebuild the hydro-gear transaxle due to some gears breaking and being shot through the case . I got the transaxle put together and on the mower but I have 2 left over springs that I am not sure where they go and I cannot tell from the manual. One spring looks like it is part number 142431 but the exploded parts list is not clear where this part goes. The second spring is similar in style to part number 106888X but I cannot even find the part on the parts list? The mower seems to operate fine without either of these.
    Loyalty:
    Visited the website for 30 consecutive days.
  • Craftsman Master
  • 1,669 Answers
Best answer i can give you is sears parts direct you can download a owners manual
Posted on Dec 30, 2017
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: Weedeater Clutch Spring Replace
Counter man at the local mower repair shop said to use a thin rope. Tried it and it works great. Think I over engineered this problem.
Thanks for your help.
Wayne
Posted on Sep 23, 2008
Anonymous
  • 6 Answers
SOURCE: Craftsman Transmission problem
Some of these tractors have a friction wheel that is driven off of a flat wheel on the bottom of the engine drive shaft. The rubber ring on this friction wheel could be worn out, or it could be out of adjustment.
Posted on Apr 22, 2009
Anonymous
  • 389 Answers
SOURCE: ariens 1440h cutting problem
moz-screenshot.jpgGo to this site: http://www.ariens.com/corporate/pages/partsradar.aspx (copy and paste in your address bar)
follow the instructions given and you can download a VERY GOOD picture of where it goes
Posted on Sep 29, 2009
kel1guy2002
Kelly
  • 3740 Answers
SOURCE: lawn mower has hydro gear transaxle reverse was
Most of the time when this happens the reverse shift linkage is too short. It is usually cause by either a bent linkage or worn linkage bushings.
The internal shifting fork can be bent inside the transmission which is rare but does occasionally happen... most of the time it is a linkage problem. Also check on the side of the transmission to make sure the shifting lever has not moved from the original position on the Yoke shaft.
Thanks for using FixYa.
Kelly
Posted on Mar 29, 2010
Transmission repair or replace
Jim, The links below are what I found on the Net., You could also do a search with your year, make and model# for possible better results. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Rebuilding lawn tractor transaxle Part 1 of 2
1 Hydrostatic Garden Tractor transmission rebuild 1 of 4 Hydro Gear
Tractor hydro transmission rebuild part 1
Part 1 K46 hydrostatic drive Removal
MTD Transaxle Basic Rebuild Replacing all Bearings Part 1 of 2
Aug 20, 2016 | Huskee Tractor Replacement Riding Lawn...
How do I install seal in the transaxle?
Require splitting the case if your trying to replace axle seals. Case is sealed with Permatex Ultra Grey sealant
Oct 16, 2014 | Craftsman Garden
How to put oil in transaxle
You should have a plug in center of axle. Takes 14mm wrench.
Apr 12, 2014 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Husqvarna gear oil
I assume you are referring the the transaxle? The replacement oil in the transaxle is as follows: This model ran either a Hydro-Gear or Tuff-Torque transaxle. If Hydro-Gear use: 20W50 synthetic. If Tuff-Torque use: 10W30 synthetic.
Apr 02, 2014 | Husqvarna Lawn Tractor Gth26k54t Owners...
Brand new riding lawnmower, stop on hill, set park break, ready to go foward and when I push foward pedal and release break mower free whells backward. has 1 hr. on it. purged the trans. per instructions...
Sorry to hear about your problem...you aren't the only one having it. Sounds like a hydrostatic problem or a pulley freewheeling on a shaft somewhere. If you bought your tractor at Sears they might could help you---the husky and are the craftsman are the same. Husky uses a little better engine is all. Hope this helps.
Jul 11, 2011 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
I have a hydro gear transmission i have changed oil and when it gets hot it will not move it is a simplicity rider 2000 mod.i need help please my email is wunrau@mymts.net thank you kindy
Your transmission is shot. You need to buy a new or used one and install it. Or there may be a rebuild facility which will rebuild yours. Either way it will not be cheap.
Aug 12, 2010 | Garden
Have 2001 celica has a faulty center shaft bearing in the gear box, how bad is that?
That is real bad. Eventually, the bearing will have a critical failure, and the bearing will break up. This will lead to peices of metal in the transaxle, and the pieces will get between the gears, and snap the teeth off of the gears. This will result in the need for a replacement of the transaxle.
At this point, you either need to get it fixed, or be prepared to locate a replacement transaxle.
I have observed this several times. Each and every time, I ended up replacing the transaxle. One case had a chunk of the outer case blown off, from the peices breaking up inside the transaxle. Plus, it gives you no warning when it ultimatly fails.
Oct 27, 2009 | 2001 Toyota Celica
Peerless Transaxle #206-545c locked up in 3rd gear, wheels won't
Sounds like your going to have to open up the tranny....
Sep 05, 2009 | Craftsman Garden
Change the v-best on a craftsman 42' mower 6 speed transaxle lawn
if your going to do this get a book its not going to be easy.so you need a book i say take to shop.let me know
Jul 21, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
1995 dodge dakota transfer case problems 3.9L V6
It sounds like you already have a Tooth Broken of of the Main 4X4 Gear inside the Transfer Case. Most Tranny Shops will rebuild these along with Tranny's. You might want to get a Rebuild or at least let them Find out Which Gear is Busted. Please Rate My Response! Thanks!
Feb 05, 2009 | 1992 Dodge Dakota
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
210 people viewed this question
Top Craftsman Garden Experts
john h
Sheldon Dedek
rjivaro
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
