Master
- Posted on Jun 15, 2010
Re: How do I get the hard drive out
Unplug
the computer. As a safety precaution the hard drive removal should not
be attempted while the computer is still plugged into the house current.
Pull
the cover off the computer. This should be as simple as removing a few
screws and sliding off the cover. If the process seems more involved
that this, then consult your owner’s manual for the computer.
Locate
the hard drive.The hard drive usually comes in the shape of a
black-plastic rectangular box enclosed in a metal casing. It is linked
to other components by a unique connecting device that is easily
recognizable. This device is a long plastic ribbon-like cord that has a
long interlocking and connecting device attached to it.
Remove the metal housing. This should be as simple as removing a few screws.
5
Disconnect
the hard drive. All you have to do is pull the interlocking end of the
lock ribbon cord until it coves free. This should not require an
extraordinary amount of strength. It is similar to pulling an
electrical cord from a wall socket.
Read more: How to Take a Hard Drive Out of a Computer | eHow.com http://www.ehow.com/how_4450021_take-hard-drive-out-computer.html#ixzz0qvQCfJhS
Step 6
Unscrew
anything that is still holding the hard drive in place and then pull
the hard drive unit out of the computer. Now you can externally hook
the hard drive to another computer to double check the data base. For
this you will need an external holder, which you can purchase for $25
to $50 at your local computer store. Or you can add the hard drive unit
to the inside of another computer tower.
Read more: How to Take a Hard Drive Out of a Computer | eHow.com http://www.ehow.com/how_4450021_take-hard-drive-out-computer.html#ixzz0qvQ9MXYe
Step 5
Disconnect
Read more: How to Take a Hard Drive Out of a Computer | eHow.com http://www.ehow.com/how_4450021_take-hard-drive-out-computer.html#ixzz0qvQ5WTOQ
Step 4
Step 5
Disconnect
Read more: How to Take a Hard Drive Out of a Computer | eHow.com http://www.ehow.com/how_4450021_take-hard-drive-out-computer.html#ixzz0qvQ1AnQp
Step 3
Locate
Step 4
Step 5
Disconnect
Step 6
Unscrew
Read more: How to Take a Hard Drive Out of a Computer | eHow.com http://www.ehow.com/how_4450021_take-hard-drive-out-computer.html#ixzz0qvPuIEwv
Step 2
Pull
Step 3
Locate
Step 4
Step 5
Disconnect
Step 6
Unscrew
Read more: How to Take a Hard Drive Out of a Computer | eHow.com http://www.ehow.com/how_4450021_take-hard-drive-out-computer.html#ixzz0qvPnVKmo
