According to my data, you'll need a Briggs and Stratton Part No. 692051 for that machine. Cross reference to Champion Plug RC12YC. Note that this plug shows a recommended gap of only .020, as opposed to the .030, most Briggs plugs use. Best of luck to you.
Hello there:
The recommended spark plug gap for a 2003-2004 Honda Odyssey is .044"
Keep in mind, many OE manufacturers (i.e. Denso, NGK) pre-gap their
plugs for specific applications. If you happen to buy the iridium or
platinum style plugs with the very thin center electrode, they should
come pre-gapped. It can't hurt to check the gap before installing
the plugs, but if any adjustment is necessary, do so with caution
because the ultra-thin electrode may crack if any excessive pressure is
placed on it.
Hope this is very helpful Best regards Michael
check the gap on your plug. .030 is what it should be. also make sure that your kill cable is working properly and not grounding the engine out. the gap for you magneto should be set to .010 to .012 loosen up the magneto insert a standard business card or 3x5 card then turn the flywheel so that the magnet on the flywheel pulls the magneto into it. then tight the magneto mounting screws down. try spark now. always use fresh gas. -no-water- if in doubt throw it out. gas is BAD after only 30 days.
