Question about Whirlpool GS6NBEXR Side by Side Refrigerator
No water from the water dispenser.
I have a new whirlpool side by side refrigerator. After hooking up the water in the back for the dispenser, The ice is making and dropping perfectly, but when I press a glass against the water dispenser lever, there is just a humming noise but no water comes out. The manual says there is a switch at the top right inside the freezer door, but there isn't one there. Can you help me?
  • 166 Answers
A new refrigerator has a water resevoir that has to fill up. you have to hold the water dispenser down for a minute or so to allow this resevoir to fill.
if you have done this already, then you probably have a bad water valve.
Posted on Jun 12, 2010
Testimonial: "THANK YOU!!!!!!!!!!!!!!!! Why can't they just tell you that in the manuel. It would save a lot of frustration. Anyway, I will be sure to check with FixYa the next home project challenge I have."
6ya staff
SOURCE:
Can't get Ice/Water to dispense, I hooked-up the water hose from the water source to the refrigerator, turned-on the water, left the freezer bar in the "On" position, and unlocked the dispense. I verifed...
If this is a new purchase, you will have to depress the water dispenser lever long enough for the water to make it all the way through the system, including the water tank located inside the fresh food compartment.
Aug 13, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker not putting out water just hooked up ice maker kit
Are you getting ice? It seems like my brand-new electrolux does not produce cold water unless it is producing ice as well. We had to adjust the auger in the ice tray to start getting ice ... seems like our water is now getting colder.
Jul 05, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a Whirlpool Imerial Series Side by Side that will not disp
If you can't hear the solenoid on the water inlet valve(it's on the back where the water supply hooks up) when you try the water then the water switch on the dispenser is at fault.
If you do hear it Your water line could be frozen in the door. You can disconnect the line at the bottom before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does, leave the door open till it thaws.
If it doesn't come out there disconnect it at the water inlet valve and see if it comes out there. The valve could be bad.
Nov 17, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice Maker Works, Water Dispenser Doesn't
I have a whirlpool side by side. water and ice in front. ice working and water not. the hose is not frozen and it is not humming when you push the water dispenser. It would give us water and quit but now we have nothing.
Jun 25, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ed25rfxfw01 whirlpool fridge water dispenser ...I have a slow drip from the dispenser hose. I assume I need a new water inlet valve. How do I access the inlet valve for replacing?
It should be on the right hand side in the back take off the compressor cover on the back should be 8 or so 1/4 screws nutdriver type and then two more hold on the water valve. If you have a RO system hooked up to refrig you may need to change the filters on the ro or just change the filter on the refrig. those two will also cause the water to drip thru the valve allowing it to drip on the front
May 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Cold water dispenser on new whirlpool side by side dispenses lukewarm water...ice maker works a charm
there is a tank in the refrigerator section that hlds about 1.5 gal of water as you dispense it refills and pushes out the cold water. if your unit is new it will need a day to cool down the tank of water before you will get cold cold water at the dispenser
Hope this help explain how it works
Aug 01, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
407 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Bruce Denton
jdthefixer
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
