Try this: Soak the stained clothes in a solution of 1 quart of warm water, 1 teaspoon of liquid dish detergent and 1 tablespoon of white vinegar for 15 minutes. Then, rinse with water.
If this doesn't get everything out, then wash in warm water (or what the fabrics allow) using a color safe bleach and detergent.
The problem is that there was more dirt than what your detergent could handle. If you have a really dirty clothes item in the future, get as much of the dirt off using a vacuum or by soaking alone as you can. Then wash the item in warm water with detergent and color safe bleach.
SOURCE: Awful smell in drum of washing machine
My friend told me of someone who researched this problem, and it is because we are using liquid detergent. Switch to a granular high efficiency detergent. Before you start using it, you must run through a mixture of about one cup Clorox and two cups vinegar through the washer, using the Sanitary setting. I am actually on-line now trying to research the exact proportions of Clorox and vinegar when I ran across your problem.
SOURCE: Water Softner Dispense wont empty - Kenmore Elite Quiet Pak 4 HE3t
I'm sure you heard a small motor running from time to time during a cycle. That moves an "arm" which sends water to the different chambers during a cycle. Fabric softener is dispensed when water goes to that chamber and dilutes the fabric softener. That chamber then empties by a siphoning action.
If you want to narrow down the problem a little to help trouble shoot -- put some wet rags in and run the Rinse and Spin cycle with some fabric softener. If the softener is not dispensed, then you know that the water isn't being sent to that chamber properly.
If you are intrepid enough to take the top off your washer, do that and see if the arm appears to be moving during a normal cycle. Maybe the arm got dislodged or broken during the move.
If water isn't being diverted properly, I think this calls for a real repair person.
SOURCE: How do you do a Pre-Soak cycle on Kenmore front-loader
I can send you a PDF of the manual let me know..
SOURCE: Also can't get whites clean in out front load washer
try using a bit of automatic dish soap in with the detergent and bleach .Ifound that to do wonders
