GE WBSR3140DW Top Load Washer Logo
A
Anonymous Posted on Jun 11, 2010
My washer stopped during the spin cycle. Now I can get it to fill with water But aggitate and spin it just makes a noise and the tumbler is locked up tight
wwlvictoria
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • GE Master 1,001 Answers
  • Posted on Dec 02, 2016
wwlvictoria
GE Master
Level 3:
Renaissance:
Answers
1001
Questions
0
Helped
603647
Points
6027
Chornic hope you Enjoy garden watering and make garden watering easy and convenient.
1)Compact, lightweight, tightly leaves a pleasing impression on you
2)Solid brass fittings ensure a longer and working life and no more worries about leaks.
3)Newst and improved aluminium clamp fixed connection and crush resistant metal fittings all prevent leak. Chornic 100FT Expandable Flexible Garden Hose Pipe Aluminium Fittings with...
Sheldon Dedek
Level 3:
  • Master 912 Answers
  • Posted on Jun 11, 2010
Sheldon Dedek
Master
Level 3:
Answers
912
Questions
0
Helped
306609
Points
3298
Your shaft coupler / motor coupler has likely broke. Not too hard to fix yourself, but you will have to remove the water from the washer first.
Remove the clothes, place them in the bathtub. Roll a garden hose from the washer to outside where drain water won't matter. Tape the garden hose to the drain hose, and lower the drain hose to the floor. Water will flow through the garden hose outside. Turn the washer over, follow directions supplied with new part, and replace the motor coupling. When finished, reorient the washer, remove the garden hose, place drain hose in the drain stand pipe. Run the washer through a couple of full cycles, then rewash the clothing.
My whirlpool Estate washer is not draining or spinning but aggitates, what can be the problem?
Sounds like a cycle switch problem. The switch is not turning and making contact with the next cycle. It needs to be changed!
Water coming from bottom white round piece of washer during aggitation
Could you please describe the problem you are having a little better?
My washer fills with water then it makes a noise like there is something stuck and aggitator won't spin
You need the Service manual to start troubleshooting. There could be something jamed under the tumblers. The Service Manual will get you stareted,
Google this Neptune TL Washer FAV6800AWW
You will find FAV6800A or FAV8800A help.
3helpful
Making an awful ratcheting noise during aggitation and spin cycles
Under the agitator there is a rachet mechanism that works the agitator. If it is stripped, it will skip until the next good tooth.. when it fails entirely the agitater will stop going back and forth. Its nylon and age along with overloading hastens its dearg.. If you can get the parts you can replace it yourself without difficulty. There is a single bolt in the center of the agitator top . Remove and loft agiyator straight up.
Loud noise when aggitating code says motor not rotating properly
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
or something stuck up in spinning motor assembly.
thanks and plse do not forget to accept the solution.
Kenmore series 70 washer won't stop agitating when lid Is lifted.
I have a Series 80 and when I lift the lid it does not stop aggitating when in wash mode. When I lift the lid it does stop spinning when in rinse mode. As designed.
To stop wash-mode aggitation at lid-lift, using the existing lid switch and other electrical components, is not easy and not recommended. I can think of a way to do it (triple-pole lid switch) but I will not detail the idea .. for safety concerns.
To stop aggitation, simply use the main settings dial control. You'll save money and possibly prevent a fire hazard!
Noisy Washer
may be blocked outlet pipe or depending on the model a noisy drive belt, check for blockage if belt do not worry. Regards engineer
Top GE Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Virgil Watts
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
