Question about Electric Garden
I need the battery wiring diagram for HomeLite UT13122. I took out the old batteries without documenting the wiring thinking it was in the manual.
    New Friend:
Short blue cable goes between the negative and positive terminals on one side of the battery.
Thick white from cable that goes to the switch and thick wire that comes from negative terminal of motor go together with the small black wire from the hood - connect all 3 wires to the negative terminal on other side.
Thick green wire from cable that goes to the switch goes with the thin red wire from the hood - connect both wires to the remaining (unused) positive terminal.
Posted on Jun 19, 2010
  • chart8
    chart8 Aug 11, 2012
    Thank you, thank you, you saved the day. Manuals that come with stuff are mostly worthless.
6ya staff
SOURCE:
I have a Homelite 24v cordless lawn mower model UT13122 that doesn't run
im not exactly familiar with this model , but a few of these new fangled lawn mowers have come my way in the past , what I've found on most of them there susceptible to the same problems the power mower have , they have safety switches and hold handles that do malfunction , also they do have battery's and those are susceptible to bad dirty connections
Jan 20, 2017 | The Health & Beauty
Wiring diagram 1999 buick century. Starter engages when battery cables are bolted to battery.
-the wires are not correctly re-installed for the starter.
- u may need wiring diagram
Did you take pictures before you took it apart, or did you tag wires before unconnecting them.
Mar 12, 2015 | 1999 Buick Century
Does the reset button need to be hooked up?
Yes of course if it was made with the unit its was important then as
well as it should be now contact manufacture. Reset buttons reset micro processor functions as well as reset the unit memory capability.. Hope this helps God bless
Oct 15, 2014 | Jet 3 Ultra Power Chair
Wiring diagram
rear battery wire connects to positive red terminal,then rear battery to negative black terminal,battery terminals facing inward,front battery to other batterys positive red cable ,wire labeled front battery to black negative cable,plug wire harness into quick disconnect...page 40 of owners manual
Need Homelite Mower UT13122 wiring schematic to check switch problem. Battery fully charged
Check the switch for current flow with and without the key. Then make sure the ground switch is disengaging when you pull the handle.Possible stretched cable.
Dec 11, 2012 | Garden
I need a wiring diagram for 2006 fleetwood exscursion 39s diesel 6-volt system
I am sorry but fixya has no wiring diagrams available for download.
Aug 06, 2012 | Cars & Trucks
I need a wiring diagram for a homelite HRI4400HD generator please.
Go to Homelite's web page http://www.homelite.com/ and you enter your Model Number and download the Owner's Manual, that should have wiring diagram in it. If you don't find it. contact Homelite Customer Service.
Hope this helps you find what you need.
Apr 18, 2011 | Heating & Cooling
Homelite ut13122 replace battery,need a wiering diagram
I have seen the wiring diagram and it does not make sense to me. I normally write a diagram of the wiring when i take the cover off to keep things straight.
Sep 30, 2009 | Homelite Garden
I need to know how to hook up the batteries. I
Hi there. Please look on the battery slot and check if you can see a
+ - sign. Check the link please for the diagram:
www.dixiesales.com/ipl/705/Homelite%20battery%20wiring.pdf
May 15, 2009 | Garden
Dash lights not working, shift console lights not working
Check the wiring to the dimmer switch. Sounds like there is no power at the switch, so get a wiring diagram and trace it back toward the battery. There is either a short or open in the circuit path.
Nov 21, 2017 | 2002 Hyundai Accent
Garden Logo
2,616 people viewed this question
Top Electric Garden Experts
Steve Oakes
Steve Oakes
dannydoesita
sgtstrat
Level 1 Expert
Are you an Electric Garden Expert? Answer questions, earn points and help others
