Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
Posted on Jun 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a craftsman LT1000 with a B S 20 hp twin motor. Recently it started backfiring after it runs for about 10 minutes. Only after it's warm it backfires. I changed the oil and filter, plugs,fuel filter and the gas but it still backfires after it warms up. Any ideas how to fix this?or what may be causing it to backfire? thank you
Anonymous
Level 2:
New Friend:
  • Expert 46 Answers
  • Posted on Jun 09, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
46
Questions
0
Helped
20626
Points
112
Carb is running a tad rich and the fuel collects in the muffler. My 20 twin has done it since I bought the thing and that was almost 8 years ago.
Cut the engine idle down before you cut the key off and minimize the bang.
Someone else may give a better explanation of the why but it is just annoying and personally after rebuilding the carb and checking the fuel pump on mine it still does it on occasion. Hasn't hurt a thing on in all these years and I actually thing it blows the soot out of the muffler when it does.
1helpful
Craftsman mower backfires out the exhaust when starting warm motor
Sounds like it is letting unburned fuel thru the carberator and getting ignited by the hot exhaust. Your carb is out of adjustment or could be worn out.
Has anyone ever had a problem with the fuel solenoid on the carburetor? Same B & S 20 hp v-twin. If it were malfunctioning could it cause a backfire through the carb?
A bad solenoid on the carb should not cause this. It sounds more like to me the motor is out of time due to a sheered flywheel key. Appears as though the motor is firing while the intake valve is open which is why you are getting a so called backfire through the carb. I hope this has been helpful.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/steve_f5a6ca85b5d1ffc9
3helpful
2answers
Briggs and Stratton 20 hp intek runs great idles great but after running for 15 min. it acts like is running out of fuel and dies. it starts back up if you wait a few min.fuel filter new , plugs new air...
Had the same problem with an almost new Craftsman w/ Intek 20.0 HP. Check all the "usual suspects" and had to have a tech come out. He had me start it. It ran for a few minutes and stopped (per usual). He immediately went to the Anti-Backfire solenoid. It is an electrically operated "plunger-style" fuel line blocker. They are famous for going bad. The part is about $65 and its sole purpose is to starve the engine of its fuel supply at shutdown so it won't backfire. If it is disabled, the user must throttle the engine down for 10 seconds or so before turning the key off in order to avoid backfires. Gee... let's see, 10 seconds of my time each time I use the mower vs $65 part ... No contest! Remove the solenoid, take a pair of electrician side cutters and snip off the tip of the plunger and reinstall it. Problem solved ! ! !
18.5 hp Intek V-twin mower starts well and runs good till it gets hot, then starts missing and backfiring.
For some reason your carb is getting to warm and it is vaporizing the fuel
If you can remove the hood try running it without it to see if that problem still exists
Mar 09, 2010 • Garden
Briggs and Straton 8 hp, craftsman snowblower stalls
Sounds like you coil is over heating after running a few minutes. The windings are seperating, then when it sools they make contact again. Try replacing the coil.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
After about 30 to 40 minutes of use (varies, the
I have a 7 year-old craftsman mower with a 22 HP Briggs engine that has the same issue. After about an hour, the mower acts as if it is starving for fuel and then stalls. Then after about 5 minutes of sitting, it will run for a little while longer.
If your engine is similar to mine, then its carb has a fuel shut off solenoid which shuts off fuel to the Main Jet when Voltage is removed to prevent backfiring when the key is shut off.
Unfortunately, this solenoid can also cause the carb to starve for fuel when not working properly. In my case, when I cleaned the solenoid and the solenoid's connections, the tractor had no problem after that.
Hope that helps,
Steve
I craftsman 20 hp twin mower quits after waarm up
SOUNDS LIKE A FUEL PROBLEM OR DIRT WHAT OTHER SYMPTONS DOES IT HAVE
2helpful
Craftsman mower backfiring
if a camshaft came loose the engine would not run at all. IF engine still runs then i would change the head gaskets. these things **** air and cause backfiring when running. but if engine doesn't run anymore i would look on ebay or craigslist for local mower for parts at least.
2helpful
Sears 19 hp twin 42 inch tractor, won't start if hot
Hi
Two things come to mind. First it could be not getting enough fuel when hot due to carb adjustment being too lean. That could be that the float level in the carb is set too low or the low speed jet is set too lean. When cold the choke circuit in the carb supplies the extra fuel required.
Second in some enjines that have low compression they start cold but when hot the compression drops below 60 psi and makes starting very difficult until engine cools down.
I suspect a fuel problem.
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
