SOURCE: Amana bottom freezer/ refrigerator
Geezer, sounds like a defrost issue. I usually find the bi-metal to be the culprit on this model. Check out the pic. You will have to remove the back panel in the freezer and defrost the evaporator. Remove the ice maker if there is one. The back cover has 4 quarter inch screws. remove those. The air vent has 2 plastic clips one each side and one on the bottom, push in and pull the grill off. The thermistor cover has a slot for a flat blade screw driver,push in and pull the cover off. The thermistor will now slide behind the back panel. Check the bi-metal for buldging. As long as the evaporator fan is working, it's probably a defrost problem.
SOURCE: Amana refrigerator only not working
Few questions first. 1. What is the entire model # on the sticker inside the fridge section? 2. Is the fan in the freezer running? 3. Is there a thick frost build up on the back panel in the freezer (look at the bottom half for a side by side)?
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
SOURCE: refrigerator not cooling
This could be that it is out of balance. Set the temperature settings to midway. This control can easily get the fridge temp out out of balance if over adjusted. If you already have the tmp control at midway then you need to make sure there are no obstructions to the duct that carries the cold air from the freezer to the fresh food section to cool it. Check for ice buildup or any kind of blockage. Let me know what you find.
SOURCE: AMANA BG21VL REFRIGERATOR ISN'T COLD,
check in frezzerto see if your evap fan is blowing if not need to replace it if its is u will have a defrost problem u can unplug for 4 or 5 hrs with doors open to defrost itsself . plug back in will work fine till u can replasce heater and tsat.
