Washing Machines Logo
Anonymous Posted on Jun 08, 2010
My lg gets a code of ue - LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
Dan Webster
Level 3:
  • LG Master 8,221 Answers
  • Posted on Jun 08, 2010
Dan Webster
LG Master
Level 3:
Answers
8221
Questions
5
Helped
2380794
Points
25840
UE error:
Too small of a load
Unbalance load
Appliance tilted
Non distributable items in drum.
Need a manual?
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
4 Related Answers
Anonymous
  • 6784 Answers
  • Posted on Aug 08, 2009
SOURCE: "UE" error code LG washer wm0642hw
This is an Imbalance code. Your issue may be with:
  • The load is too small
  • The appliance is tilted
  • Laundry is gathered to one side
  • Non-distributed things are put into the drum
Try adjusting the load size, and make sure the unit is level.
Anonymous
  • Posted on Mar 12, 2010
SOURCE: Error code UE on LG F1247 TD5 washing machine
it means uneven load do u have a pillow in there or something that soaks up lots of water!!
Anonymous
  • 1400 Answers
  • Posted on May 04, 2010
SOURCE: Code UA or UE keeps on comin up on my lg
Hello
Hold down the pause and cancel buttons for 5 sec.
Or unplug unit for a min and plug back in to reset.
TheMobilian
Dan Webster
  • 8221 Answers
  • Posted on May 20, 2010
SOURCE: LG washer Model # WM1814CW problem code UE
UE=Imbalance error
load too small
appliance tilted
laundry clumped to one side
non distributable object in tub
2helpful
LG top load washer has a 'UE' Error.
Question edited for clarity
An LG washer displaying the UE or uE error code means that the load in the washer is unbalanced. ... When the uE error code is displayed, it means that the washer is trying to resolve the issue. The washer will fill with water to try to balance the load. It will then drain and try to spin again.
Jun 7, 2021
How to Fix the LG Washer UE Error Code - Fleet Appliance
https://fleetappliance.com > News and Tips
5helpful
I am getting alert of UE for fully automaticatic washing manchine
According to Lg Ue error code is an unbalanced load error code or uneven load error code you can also click this link from the LG site which describes some ways to alleviate the problem of the UE error code http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=800. I have also found that if these ways do not remove the problem you may have to open the unit and check the damper struts that attach to the tub assembly. If one of these struts were not to be attached or have broken, or came away from the tub assembly this would also cause the UE error code as well with the unit. Also if you remove the rear panel you will see the stator which is basicly the motor as well as an rps sensor which helps the stator to rotate. I also have found that in some cases the center bolt that holds the stator in place sometimes unloosens and unscrews as well also causing this UE error code. So you would first try the methods that LG has listed in order to alleviate the UE error code and if there methods did not work then you would first look at the stator center screw to assure that it is tightened and in place. And secondly if the stator screw were in proper place and tight then you would look at the damper struts in the unit lastly. If you have any further questions message me back and please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future Thanks
Rick
2helpful
2answers
UE=Imbalance error
load too small
appliance tilted
Hello
My Lg washer is showing a code UE and then PF what can I do to fix this problem.
UE means that the load is unbalanced in my LG. The code PE means that the water sensor is malfunctioning and needs replacing.
4helpful
Error code UE on LG Front Loading Washing Maching
this is what i just found on the internet...
With any washing machine, it is vital to ensure that the load is evenly balanced when using a spin cycle. Redistribute washing by adding or removing items to ensure a more balanced load. ... If the door remains locked and the machine is displaying UE error, please run a drain program.5 Jul 2016
My Samsung washing machine is showing a UE code during a spin ...
or try this link..
Error code UE on LG Front Loading Washing Maching Google Search
11helpful
2answers
Code error ue lg washing machine
ue is (imbalanced error) cause. the load is to small,washer is tilted, laundry is gathered to one side, non distributed things are put into the washer
5helpful
LG WM 14316FD washing machine
An UE Error Code is indicative of a “Unbalanced Error”. This indicates that the drum is not spinning in a smooth rotation. It may be necessary to rearrange the load in the drum. I found this answer on the lg web site.
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
