I have the list of codes for this remote, RCA R55L8-RCR4358, How do I ENTER the codes?
There are 4 ways to program your remote:
-Brand Code search and entry
-Direct code entry
-Manual Code search and entry
-Auto Code search and entry
*ON TV/VCR(DVD) combos you must program each button individually and that button(ie. TV or VCR/DVD) will program that part of your device.
*the DVD/VCR button programs DVD by default, in order to program it for VCR you must put it into VCR mode:
1.hold down the DVD-VCR button-->the red led will stay lit.
2.while holding down the DVD-VCR button press the number 2 --> the red led will turn off
3.Release the DVD-VCR button--> the red led blinks 4 times and turns off
4.The DVD-VCR button is now set to VCR mode-->program for VCR
BRAND CODE SEARCH ENTRY:
1. turn on device
2. locate brand codes(sorry, I don't have it, try finding genaric RCA codes)
3. hold down the component button--> led should stay on
4. while holding component button, also hold power button--> the led will turn off, then after 3 seconds it will turn back on.
5. release both buttons--> led will stay on
6. enter brand code--> led blinks once
7. press power button repeatedly until component turns off-->each time you press the power key the remote sends a different code for that brand. led blinks once
8. if power on your device turns off press the stop button to save configuration-> led turns off
9. if the led blinks 4 times and turns off, you have reached the end of the codes for that brand, try using a different method to program your device.
DIRECT CODE ENTRY:
1. turn on the device
2. locate your device codes
3. hold component key down-->led lights up and stays lit
4. enter code while holding components key--> as first key is pressed the led turn off, then as 4th digit of key is pressed the led turns back on
5. release component key-->led turns off, try using your remote, if it doesn't have all of the functions you need, try a different code
6. if the led blinks 4 times after entering code you have entered an invalid code, try again.
MANUAL SEARCH AND ENTRY:
1. turn on device
2. hold the component button--> led lights up and stays lit
3. while holding component button hold power button-> led turns off then turns back on after 3 seconds
4. release both buttons--> led stays lit
5. push the power button a bunch of times until the device shuts off-> each time the power button is pressed a different code is sent to the device, the led blinks each time.
6. if the device turns off press the stop button to save your config.
7. if the led blinks 4 times you have reached the end of the code list, there are hundreds of codes, you may be pressing the power button for a while...
AUTO CODE SEARCH AND ENTRY:
1. repeat steps 1-4 of "manual search and entry"
2. press the "play" button--> led blinks 10 times, sending a code each time
3. continue pressing the play button until the device turns off
4. if the device turns off press the reverse key to until it turns back on then press the stop key to save config.
5. if the led blinks 4 times you have run out of codes, try a different method.
Now if someone would please post the codes, or if someone knows the code for a durabrand DVD-1002...
I need an replcement remote,or could you tell my where to purchased one for.my home theater system. I have an rca with the model #rt2770 .thanks melvina anderson [email protected]
RCR4358 solution
after hours of searching, I found this and followed the instructions it worked for me. hope this helps you all out
1 Hold down the television and power button till it turns red
2. Then press play once the light will blink once it stops if the t.v. has not turned on press again, continue until the t.v. turns on.
3. Press reverse until t.v. turns off
4. Hold down stop till light goes off
Thanks that code worked, when you hold down tv and power. then hit play
Programming Your Universal Remote.
The remote may already be set up to operate your brand of TV, VCR, or
Cable Box. It is pre-programmed with following codes:
For brands that
require programming, there are two ways to program: Using Code Lists or
Code Search. Use Code Search if the code lists are not available or if
the codes from the lists do not operate a device.
Programming a Device using Code Search:
Programming a device using the Code Lists:
Normal 0
How do I connect my RCA Universal Remote to my Element TV?
I have a lg flatron tv. it's brightness is very low after i put its brightness in 100. how i can adjut it
There is not a CODE SEARCH BUTTON on this type of Remote
Just so you know
batteries are OK but no longer operates the unit. cannot reprogram it. steps to take do not work as described in another how-to site, i.e. "press button for the component you want to program...the on-off light will come on and stay on..." It does not stay on.
there is no code search how do you program this damn thing?
need remote code for Insignia digital tuner, Sanyo TV, and Magnavox # zv450mw8a. For my rca rcr4258 or rcr4358 universal remote control.
[email protected]
Where is the "code search" button??? There isn't one!!!
what code search button?
i want to know how to enter or setup code for my ilo tv
i have the RCA4358 and i lost the instruction manuel and i cant connect it to my tv
i can't enter the code ido not know how to enter
How do i program the code on my RCA universal remote control.
do not have a code search button. What button do you use instead?
