My Washing Machine has come up with an error code CL - There is nothing about this code in the User error codes.
Also the machine was not on a cycle. It worked fine yesterday, come to use it today and it just says CL on the display and wont do anything. I have tried powering down for a few mins but comes back up with CL when plugged back in.
Any ideas ???? Thanks.
The "CL" code is not an error! This means "Child Lock"!
To unlock a washing machine you will press and holding within 3-5 sec two button, marked "child lock".
And happy day will come! :))
Genius!
On the model I bought recently - LG TOP LOAD 5.0 CU. FT. WT1701CW, the CL symbol came up unexpectedly and the washer would not allow to do anything. To deactivate the CL, Child Lock, mode, a quick sheet that comes with the machine says to press and hold SOIL LEVEL button until the CL clears. This helped.
I see there are many different LG models, I couldn't find the "child lock" button on mine at first and then finally noticed it was on the "pre-wash" botton. Held it for 5 seconds and now it's fine Thanks for the great tip! Found this info quickly online which is great because I can't find my LG manual
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
The solution is your Child Lock is on. Same thing just happened to me and customer service was actually able to answer the question. Just hold the Child lock button in for
I'm about to go out now to buy a new washing machine because of this error CL, but then I tried to Google it and I came up with this page, tried the advice solution and my God it works... Big Thanks to you all.... we got a big smiley faces now.... :-)
My lg-1285fhd is showing error code oe. any suggestions.
My child was pressing the delay wash button on my machine, I don't know how many times she did this before I scolded her. Then when I tried to do the lundry tonight, the machine went through the cycles but no water went into the machine.
Please Help!
Thank-you
Sherrie
This may mean that the child lock has come on. Your machine will have two buttons that you have to press together to undo it. Mine is Temp and Options (there's a diagram on the panel)
Thanks it works guys thank you for google for this page
An update, My Wife says that it did 2 loads this morning which worked fine. Machine then turned off. Later she leaned on it while talking to a friend and the error code CL came up on the display. It has been like that ever since !!!!!
mines the same whats the answer
Same thing with mine. I just leaned on it and the code came up. FYI, I leaned on it to get to my dryer plug that had come out when I was unplugging my washer for a ue code. I called LG about the UE code and the customer servie rep helped me, but he was a total **** during the call.
My 3 month old lg wd - 80490tp is showing code cl.
hi washing machine was working yesterday now no power just saying cl error
It means child lock on. Hold the RINSE & SPIN BUTTON FOR 3 SEC.. Walah! No longer Adult and child proof.
Stands for child lock. Just press RINSE & SPPIN BUTTON for 3 seconds. Walah! No longer ADULT AND CHILD PROOF
