I have a string craftsman weed wacker an the string that cuts the grass went inside the head i can see there is plenty of string left is there a way to get it back out so i can use it
remove the spool and wind the spring hold it with a screw driver thread string and make a knot on the end release the spring and reattach the spool if you need visual instructions try Sears parts.com they will help.
? 3:55
www.youtube.com/watch?v=fFt3a3St54U
Jul 9, 2014 - Uploaded by EricL5150
This is a video on how to replace weed wacker string trimmer line in a string trimmer/weed wacker. ... This is done on a Worx string trimmer but the process is pretty much the .... How torestring dual-sided spool lawn weed eater trimmer with ... Worx56volt Cordless Trimmer Edger Review & Demo Video ...
The parts diagram above shows part #25, that part located just behind the head should have a small hole in the side about 1/4" diameter. That hole lines up with another hole inside to stop the shaft from turning . You need to line up both holes visually then insert a small phillips screwdriver in through both holes, that will hold the shaft still while you turn the whole head assembly with your hand. When removing the head assembly it should turn counter clock wise,when looking at it from an operating position, meaning that the threads are left handed.
You can find a complete trimmer head replacement at Hyperparts.com. Go into the Lookup By Application section and select the make and model of your trimmer to see a list of the heads they offer.
Very easy. There is usualy only one nut to undo. You need to grip the head somehow, to stop it turning, and simply undo the nut with a suitable socket wrench. From my experience, most of the nuts on weed wackers are left hand thread, so to undo the nut, turn it clockwise.
