Please check the video link provided below for your reference. The device used there is a iphone but the instructions on how to connect a bluetooth headset are the same.
1.) Enable Bluetooth on your phone/device and go to "search for devices" on it. Pic below is the screen on the iPhone, go to "settings" and then "general" to get there:
2.) Push the audio control button on the right side of your stereo on your speed3 a few times until "BT Setup" shows up and then spin to the right to choose "pair device" and click it.
3.) After a delay "Mazda" should show up on your device list on the iPhone. Choose it and then enter the pin "0000" and it should connect.
On your phone, make sure bluetooth is turned on (settings, general).
While
your phone is in discovery mode, turn your bluetooth device on and put
it in discovery mode ***(usually you have to hold the power button for 7-10
seconds)***
Your phone will find the device, and you will be
prompted to enter the devises PIN number (often 0-0-0-0). Your phone
should pair with the device then.
You have to search the device from your phone and enter the passcode
when it is detected. Make sure you have enter the correct pairing code and your phone has bluetooth 2.0.
On the PHONE Turning on and pairing a Bluetooth device To turn on and pair a Bluetooth device, perform the following steps: 1. At the Home screen, press the Menu key. 2. Touch Settings. 3. Touch Wireless controls. 4.Touch Bluetooth to select the check-box and turn on Bluetooth. 5. Touch Bluetooth to select the check-box and turn on Bluetooth. NOTE: The device searches for Bluetooth devices and display a list under Bluetooth devices. 6. Touch the Bluetooth device that you want to connect to. 7. If required, enter the PIN and touch OK.the Pin/passkey: 0000 On Bluetooth headset Step A - ENSURE HEADSET IS IN PAIRING MODE Power on headset by sliding the Power switch towards the microphone to initiate easy pairing. After a few moments, the indicator light will be steadily lit in blue to indicate headset is in pairing mode. Select OK.
COBY CVBT10 will not pair with bluetooth device
