IE is water inlet error...The waterinlet valve is most probably faulty...To access this you need to release the top of the machine by unscrewing the screws under the rear lip. 'Bump' the top panel back to unclip, and the inlet valve will be exposed. Make sure you mark the wires so they go back in the same positions as before.. Make sure the hoses are in the same pos'n, too!.....Good luck...Nomess
The IE fault code indicates that your washer is not filling properly with water This error code is displayed if the washer is not fully drained within 10 minutes. I will give you troubleshooting tips for both the fill problem and the drain problem.
To troubleshoot a drain problem, follow these steps:
Here are some troubleshooting steps for the filling problem:
