The blender (cyclone) does not turn on. The pulse light is blinking--I have no idea why it will not stop blinking and the blender will not turn on. It is of course plugged in. It is one week old.
This worked for me - only took about 5 minutes (the amount of time it took for me to google Black & Decker and search through their FAQ)
Q. My blender stopped in the middle of blending. What happened?
A. Your blender has a motor overheat protection system that will
automatically shut off the blender when it has been running too long
with a heavy load. If this happens, unplug the blender and wait 10-15
minutes to allow the motor to cool down. Plug in the blender and resume
blending.
I fixed mine by putting it in the freezer overnight. It has not stopped working since and I use it a lot. I suspect that this reset the overheat sensor, assuming this is a bi-metal type, but not sure why this worked or how but it solved the problem. :-)
We're having the same unfortunate issue with the overheating (blinking light). We believe we put in a medium load, which isn't too heavy. Not even 10 minutes in, the power button started flashing-
Did this still doesnt work like I read its probably a burnt out motor. try the above method, if it doesnt work, do what the other person said throw that p.o.s. away and buy an antique blender it will last forever. dont shop at walmart if your buying anything you want to last more than a week disposable ****.
In the situation that the accompanying happens the client just uproots or modifies that ingredient(s) being referred to and pushes any mix period switch, after which the gadget is immediately eager to resume work. I exhibit the accompanying element every now and then by introducing this tackle of a sort into the jug with edge while the unit is an incredible off employment, and having the thought immovably against the base in the container while at the same time beginning some kind of cycle.
It can helpful for you to as well as you can check the review from the groomandstyle.com/top-5-best-blender-reviews/
you can get information about products which is good and brand for long time.
