Well, how did he bypass the thermostat? Is it just a wire? First turn off the power to the unit and then simply remove the bypass by cutting it out or unscrewing it. I'm not exactly sure what he did, but if you take a picture and post it here of the bypass (as you can bypass something different ways) then I can tell you what to do.
If you are unable to post a picture here, email it to me at [email protected]
Let me know how this works out for you.
Benjamin
Testimonial: "Thankyou I'll try give you the details in the morning on the External Brivis Classic Gas Heating unit. The wiring on the Honeywell VisionPro TH8000 Series Thermostat is there is a bridge in the RC Cooling Power & R Heating Power(and Brown wire) W 1st stage heat relay (white wire) G Fan relay (Brown wire) Y 1st stage heat compressor contactor (White wire)."
Have you tried testing the thermostat? Check it's resistance by first disconnecting it. The resistance should be around 1000 ohms, not sure on the exact measurement at this time but let me know what you get. Also if you can send me a picture of the wiring, I do better with visually seeing it. Thanks
Did it run all the time? How did he bypass it.
I did not see what he did, however at the thermostat if the fan is set to Auto it blows cold and on On it blows hot, however bypassing the thermostat? The unit is a external Brivis classic gas heating unit with the additional ac unit (combo).
