SOURCE: drain for a colelam rv air conditioer
Your drain holes are in the base of the unit, usually just a hole or you may see round plastic button like pieces sticking down from base. Look between roof & base where gasket is, when unit is running & cooling and water should run out from that area, and across roof. Sometimes the hole in the buttonlike drain will plug up & a small stick or similar poked in the hole in side will usually open drain up again. A 20 amp breaker to run AC should be sufficient unless your running it off a long perhaps small gauge extension cord. Also be sure fridge or anything else drawing current is off in trailer, when testing AC. Hope your not running a 15 amp receptacle & wiring on a 20 amp breaker. (not safe)
SOURCE: I bought an older camper with a colman roof unit
its good to put them in, as it will keep dust from building up on the coils, thus reducing cooling.just buy some filter material at any hardware store, coarse, like a sponge, not fine paper stuff.
SOURCE: water leaking inside camper from roof mount ac
CHECK THE CONDENSATE PAN FOR CLEANLINESS, CLEAR THE CONDENSATE DRAIN LINE, INSURE THERE ARE NO CRACKS IN THE DRAIN LINE
SOURCE: keeps kicking breaker
Your unit is pulling too much power which is popping the circuit breaker. Either the compressor motor or Fan motor has a problem and you need a pro here. Drawing excessive electrical current is not good and you can do even more damage to your unit by continuing to try and run it!
SOURCE: was given a roof top ac for a popup camper need help
Make and model of unit should be on base of roof assy, please reply with that so we can be sure we have right wiring info for you. Although they are pretty common, let's be sure.
Any clicking from ceiling unit when you move thermostat through different modes?
