Plumbing Logo
Anonymous Posted on May 24, 2010
Toilet leaking into the rug and is the hotwater
Toilet leaking into the rug it is a pedal type and is the hot water gas and electric .can you tell me where to get a manual this trailer 1988 terrymanor by fleetwood
yosef
Level 2:
Sergeant:
Champion:
  • Expert 250 Answers
  • Posted on May 24, 2010
yosef
Expert
Level 2:
Sergeant:
Champion:
Answers
250
Questions
0
Helped
41693
Points
692
Toilet leaking is usually a wax seal on the bottom must be replaced you can try the ones with a rubber on it to make it last a little longer really your preference though
Checked toilets and all taps, all ok. but can still hear water running in pipes.
this is in washing machine section
if the washing machine is off
if there was a water leak in the house you would know where the
flood is by now
building wise
are people above or beside with water service
is there a basement heater /hotwater system
or is there a dishwasher
Is this a dangerous gas leak?
Any gas leak is dangerous, call him back!!!!
2answers
How to design and calculate the solar heat panel for hot water system for the concentrated 100 nos. staff toilets and changing rooms of commercial building in Beijing. What is the basic and ancillary...
Usually toilets do not require hot water.
Is the plumbing divided into hot and cold water pipes?
If toilets are hooked to hot water, how many flushes and how many gallons per flush per day.
What is the expected consumption per each worker?
What is the latitude from equator, and expected solar input. Further north, and hazy atmosphere reduce input. Beijing has smog I believe.
How often is the solar panel going to cleaned of smog and dirt for maximum collection?
If the area has hard water, then the entire system is prone to sediment build-up and failure unless water is artificially softened.
Solar water heater temperatures can exceed 180 degrees at times. This temperature will damage storage tank that is not made for that temperature.
Most solar water heater systems have pressure regulating valve and expansion tank to accommodate occasional high temperature and pressure.
A good fellow to contact might be at following website:
http://www.builditsolar.com/Projects/WaterHeating/water_heating.htm
Solar collectors are usually connected to a circulating pump, and then the heated water is stored in a tank.
The pump circulates water continually from solar collectors through a storage tank.
This type of system would use ordinary tank-type water heater for storage.
Most of these systems also utilize a back-up heating element inside the tank.
More complicated systems circulate special liquid through spiral tubes inside the water heater.
This type of heater would be an indirect water heater.
Indirect heaters are used for solar collectors, and used with boilers, or any outside heat source.
http://www.bockwaterheaters.com/Products/products_coil_tank_water_heaters.html
http://www.hotwater.com/products/residential/cirrex_solar.html
http://waterheatertimer.org/images/solar-water-heaters-on-roof_lbiRv_5784111-500x282.jpg
To light the pilot on my OS Smith water heater, I follow the instructions in the label, but nothing happens, no hot water after one hour. Read that there is problems with water heaters, I have some...
Thank you for providing clear description of product:
Your water heater has intellivent gas control thermostat.
There are always problems with water heaters. It is a huge field.
1) Open following link for AO Smith service manuals.
I do not see service manual specifically for the GP series.
http://www.hotwater.com/resources/product-literature/service-handbooks/
2) Open following link to identify gas valve and download typical service manual:
Some AO smith power vent models have intellivent gas valve, and some have smart valve gas vent. Older models might have knob-type gas valve.
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html#intelli
3) More resources:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
2answers
Rheem Pronto Hotwater Heater Error
Unplug unit from wall. Disconnect remote wires from circ board, and let unit set for about 5 minutes. plug back in. run water and see if unit comes on.
Water leaking
it sounds like the gland on the valve is leaking unusual in a valve so young but it does happen. is the valve electrical operated or water pressure. you should be able to get a complete diaphram kit with all seals etc .
Top Plumbing Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Plumbing Expert? Answer questions, earn points and help others
