Just go to https://portal.bsh-partner.com/portal%28bD1kZSZjPTAwOQ==%29/PORTALFRAME.HTM and type in the E-number for your appliance - mine is WAE28162GB/03 but you should be able to find yours inside the door on the rating plate - of it's not there try the inside of the pump filter door (bottom right of machine). The manual is in PDF format.
SOURCE: Got the Bosch Classixx 6 Express 1400 washing machine cant
Power on, press the start button for 5 or 6 seconds, the sign will go
off. Try the door gently. Means the machine is locked, for children. I think if you do
it again it locks.
Pl rate me 'very helpful' for the free help, thanks
SOURCE: Got the Bosch Classixx 6 1400 Expresswashing
think if you do
it again it locks.
Pl rate me 'very helpful' for the free help, thanks!
SOURCE: door wont open on bosch classixx 6 1400 express washing machine
The "F16" on a Bosch indicates the door is open / unlocked. If it's happening during a wash it would suggest either a faulty door lock, faulty wiring or worse, a faulty main control board. The wash program should halt when this comes up but you should be able to restart it when the door is closed. As the cost of a new door interlock isn't overly expensive. The best way to fix this problem is to purchase a new lock and fit it.
Thank you !
SOURCE: key symbol showing
