Expert
- Posted on Feb 01, 2011
Re: Polaris vac doesnt reverse . which way is it supposd...
When these pool cleaners are not reversing, there are several things that you need to check.
- Make sure that the back up valve is cycling (it should move in multiple directions).
- Check the wheel RPM and make sure that it is between 28-32.
- Make sure that the debris bag is empty.
- Check to see if the head float has water in it. If it does, replace it.
- Make sure that the feed hose is floating.
