The water fills fast on the first cycle,then fills at a trickle on rinse cycle.Whirlpool .Heavy Duty Extra Capacity top load. Thanks.
You probably have a cold inlet valve with restricted flow, either because the filter on the inlet valve is clogged or because the cold valve is failing......If you wash on "warm" you have both hot and cold water mixed. On rinse there is probably only cold water used....Check water flow for HOT and COLD settings and you'll probably see the difference...Good luck...Nomess
