Intelligent eye not working on tv
Sometimes the changes the IS makes are so small you cannot notice, but the I.S. is working.
LG’s “Intelligent Sensor” uses 4,096 sensing steps to evaluate its surroundings. Using a
sophisticated algorithm, the LG processes picture quality elements including brightness, contrast, color,
sharpness and white balance. The result is a picture optimized for its surroundings, more pleasing to
watch and which can also save up to 50% in power consumption.
1. You can go into the Menu, Picture Menu, and then Advanced. From there you can fine tune all the picture settings.
2. You can also try a Picture Reset. Inside the Picture Menu, you can perform a Picture Reset. The Picture Reset returns the “selected picture mode” back to the default factory setting.
3. If all the above fails then the problems are between the Main board (process the picture parameters) and the Intelligent Sensor (is reporting the surroundings to the main board). Either one of these issues will require new parts.
Good Luck.
