Gametime Game Time Player/Driver Buffalo Bills Watch for Women Logo
A
Anonymous Posted on May 20, 2010
BUFFALO BWC-130H01 step by step installing...
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 14, 2011
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
394
Points
Driver i need buffalo bwc 130h01 webcame
I have a mk 5055 Michael Kors watch and I don't have the proper tools with me I only have a flat bed screw driver and I need to change the battery
Read the solutions given below when you want to change the battery right from your place.
step 1: Remove the back panel of your watch.
Step 2: Locate the battery in the holder and identify its type.
Step 3: Use the user manual for reference before installation.
Step 4: Place the watch and the back panel in a plastic bag to avoid contamination during replacement.
Step 5: Remove the old battery from the watch.
Step 6: Have in hand a newly purchased battery and install it.
Step 7: Check whether the watch works after installing.
Step 8: Replace the back panel on your watch.
Step 9: Set your time and wear it.
To Get Instant Support Call our Toll-Free 1-866-293-9220
2helpful
How do i install additional links to this model watch? the company mailed me 2 additional links but no installation instructions Fossil model ES1967
  • Turn your watch on its side so the links are vertical. On the inside of the links closest to the clasp you can see arrows, which point in the direction that the pins must be pushed out. Only about four links on either side of the clasp have arrows, because these are the only links with removable pins. On the edge of the links on the opposite end from where the arrow is pointing you will see a small circle where the pin is inserted.
  • Place the tip of your pointed tool on the small circle mentioned in Step 1. Push downward on the pin in the direction the arrow is pointing. Once the pin starts to come out of the link, use your fingertips or a pair of tweezers to completely remove the pin from the link. You may need to use force, but be careful not to scratch your watchband. Use a pointed tool from a jeweler's or hobby kit or watch pin removal tool.
  • Slide the links apart where you removed the pin so there is a gap in the watchband. Slide your new link into the gap and fit the neighboring links into the new link so it matches the rest of the watchband.
  • Insert the new pin into the watchband. You will need to insert two pins, the pin you removed in Step 2 and your new pin, into the two empty pin holes. You need to insert the pin small end first so the larger pin head does not pass through the link. Insert the pin against the direction of the arrow rather than in the direction the arrow is pointing like you did in Step 2. Use your pointed tool and your fingertips to push the pins completely in the links until the pin head is flush with the edge of the link.
  • Aug 18, 2010 • Watches
    1helpful
    Does anyone have instructions for Nike Imara Fit WR0076?
    How to set time(hour minutes)/date(day, month, year)/power hour on nike imara fit:
    PLEASE READ CAREFULLY
    STEP 1:
    First hold the button for set/light.
    STEP 2:
    wait for the "hold to set" message to appear
    once it appears, keep on holding the button until the hour is ready to be set or when the hour blinks.
    TIP: Pressing the mode will enable you to choose from setting (HOUR, MINUTE, DAY, MONTH,YEAR, 12/24 HOUR FORMAT, POWER HOUR.)
    STEP 3:
    To set HOUR: press the start(for higher values) or stop (for lower values) button, choose whatever hour you want to set the time.
    *If you are done setting the time press the set/light button, and there you have it.
    If you still need to change the minutes of your digital watch proceed to step four.
    STEP 4:
    After, you have undergone step 1, & 2, or step 1, 2, & 3 (either way it'll still work), press the mode button and then, minute is ready to be set or when the minute blinks.
    To set MINUTE:
    press the start (for higher values) or stop (for lower values) button, and choose whatever minute you want to set the time.
    *If you are done setting the minute, press the set/light button, and there you have it.
    If you still need to change the date specifically, the day of your watch proceed to step five.
    STEP 5:
    To set date, specifically, DAY:
    *If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode twice. If you have undergone step 1, 2 , 3, & 4 you need to press the mode once.
    To set DAY: press the start (for higher values) or stop (for lower values) button, and choose whatever day you want to set the date.
    *If you are done setting the day, press the set/light button, and there you have it.
    If you still need to change the date specifically, the month of your watch proceed to step six.
    STEP 6:
    To set date, specifically MONTH:
    *If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode thrice. If you have undergone step 1, 2 , 3, & 4 you need to press the mode twice. If you did it step by step until 6, press the mode once.
    To set MONTH:
    press the start (for higher values) or stop (for lower values) button, and choose whatever month you want to set the date.
    *If you are done setting the month, press the set/light button, and there you have it.
    If you still need to change the date specifically, the year of your watch proceed to step seven.
    STEP 7:
    To set date, specifically YEAR:
    *If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode four times. If you have undergone step 1, 2 , 3, & 4 you need to press the mode thrice. If you skipped step 6, press the mode twice. If you did it step by step until 7, press the mode once.
    To set YEAR: press the start (for higher values) or stop (for lower values) button, and choose whatever year you want to set the date.
    *If you are done setting the year, press the set/light button, and there you have it.
    If you still need to change the 12/24 hour format of your watch proceed to step eight.
    STEP 8:
    *If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode five times. If you have undergone step 1, 2 , 3, & 4 you need to press the mode 4 times. If you skipped step 6 & 7, press the mode thrice. If you skipped step 7, press mode twice. If you did it step by step until 8, press the mode once.
    To set 12/24 HOUR FORMAT: press the start (for higher values) or stop (for lower values) button, and choose whatever format you want to set the time.
    *If you are done setting the 12/24 hour format , press the set/light button, and there you have it.
    If you still need to change the power hour of your watch proceed to step nine.
    STEP 9:
    *If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode six times. If you have undergone step 1, 2 , 3, & 4 you need to press the mode 5 times. If you skipped step 6, 7, & 8, press the mode 4 times. If you skipped step 7 & 8, press mode thrice. If you skipped step 8, press mode twice. If you did it step by step until 9, press the mode once.
    To set POWER HOUR: press start for 3, 6, 12, 24 to set the power hour.
    Press set/light to set POWER HOUR.
    How do I set the time for nike imara fit WR0076-002 wrist watch?
    STEP 1:
    STEP 2:
    STEP 3:
    STEP 4:
    To set MINUTE:
    STEP 5:
    STEP 6:
    To set MONTH:
    STEP 7:
    STEP 8:
    STEP 9:
    Top Gametime Watches Experts
    john h
    ADMIN Andrew
    ADMIN Andrew
    ADMIN Eric
    ADMIN Eric
    Are you a Gametime Watch Expert? Answer questions, earn points and help others
