Cant flash bios a1410n
Try simple first. When booting, AND BEFORE the XP logo, press f8 repeatedly until you see the boot options menu. If you miss it, you will see the xp loading logo, if so, restart and try again. From the boot menu, try the "boot with last known good configuration" option. If that doesn't fix it, re-boot, f8, and try the "safe mode" option. If it boots with any of these methods, do a full shut down and re-start again normally.
If that doesn't get it to boot normally, I would do the following. (I would, but you should only try this if you have a good understanding of windows and needed programs installing, ram replacement, hard drive repair/replacement and internal computer wiring)
Now, if your computer worked fine, then suddenly started this loop, I dont think it a bios problem. I expect you might have a hardware problem. Did you change any hardware very recently? Sometimes that stops windows from loading. Or, you could try changing the ram and retry, could be bad ram. But I think it is a hard drive issue. I think you will have to reload windows and/or replace the hard drive.
To safeguard your info, you should replace the main hard drive with another drive, load windows fully on it, then add the original drive back in as a slave/secondary drive, and retreive your personal info and files from it. Your needed programs will have to be re-installed on the newer windows drive. When you get all your files copied over (use copy and paste, not cut and paste), you can format the old drive and use it as storage, or just format and keep for the next time, or sell it. I would also run a "drive fitness program" to test it for bad sectors.
Or, if you dont need anything from your windows, you could format and install from the xp install cd. If it loads and runs, the drive is probably ok (I would still test it for bad sectors), or, if it cant load because of errors, the drive is probably bad. Retry with a new drive.
Does it spin up? The CD/DVD is ok, I presume since you were loading XP. How do you know the other drive failed? DId you test it on another machine? How about testing the new drive?
