Dishwashers Logo
A
Anonymous Posted on May 19, 2010
Cannot open the dishwasher door. Maytag Quiet Ser...
Cannot open the dishwasher door. Maytag Quiet Series 100 dishwasher... Press the door opening latch up and it stays up and cannot open door... help
  • Kelvin Irons
    Kelvin Irons Jul 06, 2018
    Just drain the machine door will open like front loader washing machine .TRUE .Good luck from Trapped
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 11, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1214
Points
This model has a problem where the handle must be depressed fully upwards to allow the latch to clear completely without straining the mechanism. The lip on which you pull open the door gives the operator a better handhold to force it open even when the mechanism is not fully depressed. Do this enough times, and the plastic tabs on the handle begin to fatigue and eventually break. The handle becomes lodged but can be forced down to eventually open the washer. By this time, a specific portion of the latch that depresses a micro-switch will most likely be broken, and the washer won't turn off if the door becomes ajar. Remove the torque screws along the inside perimeter of the door and you can spread the face panel open to access the latch unit for replacement.
  • Anonymous Jul 11, 2010
    Anyone attempting to fix appliances at home, should always observe some simple safety precautions, do not try to perform repairs if you are unfamiliar with how to disassemble components without damaging them or harming yourself, and always make sure utilities have been turned off. Double check for current in all electrical devices you will be touching by using an appropriate multimeter. Remember, just because power or fuel lines are disconnected from an appliance, does not mean that residual pressure or electromotive potential is no longer present. Try handling electrical components and terminals with only one extremity, this will decrease the opportunity for dangerous current to pass across your chest or your heart.
Maytag Quiet series 300 Handle and latch seem broken
google Maytag Quiet series 300 Handle and latch
there are several new handles about $30-35.
link to how to replace handle
copy and paste
https://www.youtube.com/watch?v=Tfw0F5XeWHY
2helpful
3answers
The latch is sticking on my dishwasher. How can I
replace the door latch and the handle check to see if the console loops that hold the latch are broken if so replace the console
Maytag MDBF750AWZ, Quiet Series 200 - sticking, stiff door handle
There are lot of handy sprays available. Try your super market or the hard ware stores where plumbing materials or sold.
May 03, 2010 • Dishwashers
5helpful
My Maytag Qriet Series 100 Dishwasher won't drain
Check the drain hose connection at the sink drain for local blockage. If ok, you may have to tear down the lower spray arm assembly down to the deck (noting orientation and position as you remove parts). Look for clogged screens and clogged openings in the deck. You can use a vacuum hooked to 'blow' to make sure these openings are clear. Wash the screens in hot water, detergent, and white vinegar to remove water and food deposits. Make sure upper and lower spray arms have open spray holes and no split seams. Hope this gets you running again!
Feb 10, 2010 • Dishwashers
4helpful
My Maytag Quiet Series 300 light is blinking 5 times by the lock button. It won't do anything else other than blink 5 times if any other button is hit. Help!!
When Control Lock is lit, all buttons are disabled. If you press
any pad while your dishwasher is locked, the light flashes
5 times. The dishwasher door can be opened while the
controls are locked.
To turn off Lock, press and hold Heated Dry for at least
3 seconds.
Dec 30, 2009 • Dishwashers
1helpful
How do I replace the latch on my maytag quiet series 100 dishwasher?
Unfortunately, the Maytag quiet series models have plastic latch handles that are prone to crack after time.
You should be able to order a replacement handle through a distribtor.
If you can, unlatch/open the door. Using a star screwdriver, unscrew all the screws on the inside of the door frame.
Once all the screws are removed you should be able to separate the inside of the door from the latch assembly.
From there you'll need to squeeze the latch handle together and replace it in. I'll warn you that it feels like you have to squeeze the thing so hard you might break/crack it on your own. It is a hard/tight fit if I remember correctly.
One last thing you may want to do to is check the food grinder in the middle of the washer. Sometimes the cracked pieces of the latch can end up there stuck in the grinder causing it to be louder than it should.
Hope this helped.
12helpful
3answers
The handle on my Maytag Quiet series 100
I had the same problem with my QS 100. I disconnected power first via the breaker then removed the 11 screws. I couldn't loosen the two electrical connections, but the door pulled far enough away to inspect the handle mechanism. The plastic handle fell out of whole handle assembly rather easily because two molded plastic pins protuding from either side had broken off and were loose inside. There was also a pair of molded plastic v-shaped forks right on the panel to hold the handle assembly and these were damaged but they just to seem to act as guides only (as the handle assembly is held in by two of the screws that were removed). Replacing the v-shaped forks would require a whole new door which I am NOT doing. It looks like I can a replacement handle in the same color with new pins (I am reading they may now be metal) for about ##15. Pretty easy to disassemble and inspect, only about 15 minutes.
1helpful
2answers
Maytag quiet series 300
Maytag Quiet Series 300. The lights flash in sequence starting from the outside traveling inward. The timer counts backwards from 50 to 1. Then the sequence starts over. and continues over and over. I'm able to clear it when the time reaches 1 or 2. It stays off for a while (3-4 hours) then starts over. I can not clear the countdown until it reaches 1 or 2. After I clear it the dishwasher will work, but until then, no way. This happens with the door open or closed.
Top Dishwashers Experts
Mike Cairns
Mike Cairns
