Hotpoint HSS25GDMWW Side by Side Refrigerator Logo
Posted on May 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Hotpoint side-by-side Refrigerator/Freezer (Model CSX22GR) that is not making ice cubes. The water lines are okay and the refrigerator is dispensing water. The ice cube tray has power and is running properly. Just not making ice cubes.
Dan Webster
Level 3:
  • Hotpoint Master 8,221 Answers
  • Posted on May 20, 2010
Dan Webster
Hotpoint Master
Level 3:
Answers
8221
Questions
5
Helped
2379704
Points
25840
Their are multiple water solenoids on these machines. The one for ice maker could be bad. I have a Hotpoint side-by-side - 847b6fd.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Hotpoint CSX22GR side by side refrigerator / freezer. Ice in bottom of freezer and water leaking on floor on freezer side. How do I find the problem??
The problem is the defrost drain is clogged, the drain is located on the lower part of the back panel and can be gotten to be removing the drawers and to clear drain push a wire hanger through it till small hole delvolopes then flush w/hot water till completly clear
Freezer defrosting by itself
what's the model number off of the fridge?
3helpful
2answers
Ice maker shooting water along wall of freezer
Hi...
You need to check this
Regards
PCmania
Icemaker making small amount of ice
I RESET THE SWITCH ON THE ICE MAKER AND TURNED THE TEMP TO 9 FROM 5 AND IT STARTED MAKING MORE ICE. I'M NOT SURE WHAT WAS WRONG BUT IT APPEARS TO WORKING FINE NOW.
2answers
Hotpoint CSX22GR water dispenser not working
Sounds like to me your filter needs replaced...how long ago have you changed them?
4helpful
3answers
Ice maker doesn't make enough ice to supply two senior citizens. This is the 2nd refrigerator we have had installed this month. What can we do to increase the amount of ice it puts out. The ice bin has...
Found in the FAQ section on Samsung.com:
Samsung refrigerator freezers produce about 120 cubes per day, which is in line with most manufacturer specifications.
Empty the ice tray and let the unit run for 24 hours.
If fewer than 50 cubes are produced during the 24-hour test, then your refrigerator requires service. Please contact Samsung Service at 1-800-SAMSUNG to schedule a service appointment.
If your freezer is producing 50 to 90 cubes per day, try the following:
  • Set the freezer temperature display to a lower setting. Freezer temperature must be 5 degrees Fahrenheit or less for the ice maker to work properly.
  • Make sure that the water valve on the refrigerator water supply line is completely open. You can find the water valve where the refrigerator water supply line taps into your house water line.
  • If you have a water filter in your refrigerator, change the filter cartridge. For instructions, see your Users Manual.
If you want your freezer to produce more than 120 ice cubes in a day, try the following:
  • An ice maker typically makes 1 tray of ice every 90 minutes. To shorten the amount of time the freezer takes to produce a tray of ice, set the freezer temperature display to a lower setting.
  • If your refrigerator has a Power Freeze function, press the Power Freeze button to speed up the ice making process. In the Power Freeze mode, both the compressor and the freezer fan run for 10 hours continuously. The ice making interval is reduced from 90 minutes to 55 minutes. If the ice bucket fills in less than 10 hours, Power Freeze stops automatically.
NOTE: If you have just installed your refrigerator, it will take 6 to 12 hours for the refrigerator to produce ice.
You should throw away the first three batches of ice cubes that the ice maker produces (approximately 30 cubes) to ensure the ice maker is making ice from clean water.
Ice dispenser only dispenses crushed ice
Check and make sure your switch is okay. Some have a switch that controls whether you want crushed or cubes. If it is defective replace it.
Top Hotpoint Refrigerators Experts
ZJ Limited
ZJ Limited
Jose Ramirez
Sean Wright
Sean Wright
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
