Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
Posted on Apr 03, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Drainage: how to open the filter then? - Bosch Nexxt Premium WFMC6400UC Front Load Washer
Anonymous
Level 2:
Sergeant:
  • Expert 351 Answers
  • Posted on Apr 03, 2008
Anonymous
Expert
Level 2:
Sergeant:
Answers
351
Questions
Helped
167370
Points
619
Hi most filters just unscrew then pull out if its stuck then theres most likley something stuck in it.but i havent worked on this model before.
1helpful
I push the button to wash and all you hear is a click on the right side and it hums but won't start, what could that mean?
Sounds like your drainage impeller is blocked or stopped working take out the filter on bottom of machine and check for obstructions....beware it still carries water when you open the filter it will drain all the water out so either have towels at the ready or drag it outside to open the filter
Sep 17, 2017 • Dryers
Washer won't drain in spin cycle?
1) The drainage hose must not stay in a lower
position than the top of the machine.
2) The drainage hose must not be bent or
clogged in any way due to the surrounding
physical configuration.
3) Open the the drainage pump filter tray, it must not have any improper substance or material inside that may cause
a machine breakdown. Ensure that the pump impeller turns freely.
Water is not draining or pumped out why ?
Do you have an HE or standard washing machine?
If its not draining on an HE machine you need to check the drainage port on it which is usually on the lower left hand side facing it. Beware there is water that will come out especially if there is water in the machine. There is probably a sock or some other items trapped in there making the drainage slow. The drainage filter on a standard machine varies depending on the brand. Usually they are on the back of your washing machine. I would check the drainage hose and the filter to see if there is any socks or other items stuck in them. That is usually the issue when the water isn't spinning out. Good luck
Pump cap won't open?
Sounds like there is a large clog in the pump filter causing it do jam. You may have to work at it to remove it, or you may have to disassemble the washer and extract the clog manually by opening up the drain lines and pulling it back from the filter.
Hi ive got water coming in to passenger foot well traced it back and found its getting in throught pollen filter any advice how to sort it
Check water box if drainage holes are open, remove all foreign matter from water box and ensure hole is open.
1helpful
The "drainage blocked" is on.
ON THE LOWER FRONT OF THE MACHINE THERE IS A COVER THAT CAN BE REMOVED
WITH A COIN OR SCREW DRIVER ---- HAS 2 TWIST SCREWS HOLDING IT ------
ONCE REMOVED YOU WILL SEE A DRAIN PLUG ON THE LEFT LOWER CORNER --
THIS HAS A PLASTIC TURN KNOB THAT OPENS BY HAND ... SOMETIMES A BIT HARD TO OPEN BUT TURN KNOB LEFT AND WILL OPEN ....... WATER WILL START TO LEAK OUT AS YOU OPEN THIS BUT DON'T WORRY -- THIS HAS TO HAPPEN --- NOT ALL THAT MUCH WATER BUT BE PREPARED TO MOP IT UP ......... NEXT PULL THE DRAIN FILTER OUT FROM
THIS OPENING AND WASH IT OUT ... ALSO REACH IN TO THE OPENING WITH FINGERS AS
THERE MAY BE SOME BLOCKAGE BEHIND THE FILTER AS WELL.. BE CAREFUL NOT TO
DAMAGE THE PLASTIC PROPELLER DEEP INSIDE THE HOLE , THIS IS WHAT SPINS AND TAKES THE WATER OUT OF THE MACHINE ....... VERY EASY TO DO ---- JUST NEED TO
DO IT ONCE TO UNDERSTAND THE PROCEDURE... UNPLUG MACHINE BEFORE CLEANING ................
I have a front loader that smells like something died in it. I have tried affresh bleach Tide washer cleaner Basic G leaving the door open cleaning the gasket washing the drum cleaning the filter and hoses...
you can open the filter drainage under near the drain hose. there may be something that comes into the washer drum and died leaving a smell. how to open the filter is rotated and pulled out only. then you try to drain the washing machine how to turn it. will allow water or sewage, which is in the drum filter out of the hole. and do not forget to clean the exhaust filter the water, there will be a lot of dirt.
1helpful
The screen is flashing F3, what does this mean?
the drain pump of the washing machine is either got loose or its not working or the drain pump is blocked. Water outlet fault (Grey Hose) If F3 is flashing in the display, there is a problem with drainage. Check: • that no objects are stuck in the drainage hose outlet. • that the drainage pump is not blocked by foreign objects. Clean the pump (see the "CLEAN THE PUMP" chapter MENTIONED BELOW FOR MORE HELP). • that there are no kinks in the drainage hose. ------------------ CLEAN THE PUMP Checking the trap and drainage pump The washing machine has a trap, where coins, hairpins and the like can get caught. To clean the filter and drainage pump: 1. Make sure the machine is empty of water and that it is switched off at the mains. 2. Open the hatch for the drainage pump as shown in the illustration. 3. Drain out the water, into a bowl, for example, by unhooking the drainage hose from the pin inside the hatch. 4. Unscrew the cover anti-clockwise and remove. 5. Remove any foreign objects from the trap and pump assembly. Check to see that the pump blades, right at the back, will rotate. 6. Screw on the cover, replace the drainage hose on the hatch pin and close the hatch.
---------- This will help.please do rate the solution if helped.keep updated for further assistance.
1helpful
A.C. unit is draining on the inside of the house.
There is a drainage and it is stucked with dust, mold etc. Just open metal lid on the wall inside your house, where the coil is installed and where you're changing filters, remove air filter, there at bottom you will see the drainage hole (now under water probably). Rent an air compressor from Home Depot or Lowe's, stick the hose to that hole and turn compressor on. This shall blow the drainage through. After that slowly pour 1-2 cups of Chlorox or Tylex in there, let it stand for 15 minutes, then pour some more water and blow with compressed air again, then flush it with water and blow last time.
Do that at least once in two years, or you gonna have same problem again.
3answers
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
