I want it to go fasteer
Before you go ahead and buy a paintball gun for you or your special someone, look for paintball gun reviews first. go to the website and read the guide. paintball marker
Try Autococker Paintball Gun.It is a semi-automated device which is one of the most popular among paintball devices. If you want to read more about autococker paintball gun then go to the link.
I can take that a couple of ways. Do you mean you want to fire more balls per second or you want the paintballs themselves to fly faster?
If you want to fire faster, make sure it's clean and properly lubed with a quality oil that made for paintball. Practice makes perfect and fire that ****** as often as you can, even without paint (that's cheaper!) so you can get your trigger finger in shape.
There are custom mods to the trigger, or you can buy a trigger that's smoother or a shorter pull. There are electronic trigger assemblies that make firing faster even easier.
If you're talking about making the balls fly out of the gun faster, that would be the "velocity adjustment". Your user guide shows you how to make that adjustment and which direction is up, and which is down.
A good suggestion is to check out a local field or paintball store, or an airsmith and they can give you some definite ideas you will want to pursue.
Play hard, play safe, play with honor!
8^)
