SOURCE: replacing the blades on a craftsman dyt 4000
Not a hard job, but you will need a couple of tools. First, you will need a wrench that fits the nut that is holding the blade on. I prefer a closed end wrench, but an open end will do. Second, you will need a blade changing tool. The brand name is called a Blade Hog. It attaches to the deck and holds the blade in place so you can turn the nut. Raise the deck as high as it will go, attach the Blade Hog, and then loosen and remove the nut. Be sure and pay attention to which side is up on the old blade and put the new one on in the same manner.
hope this helps,
c
SOURCE: craftsman DYT 4000, 24 hp 48
there is a fuse in engine compartment that might have blown causing the engine or blades not to start but what probably happened was something got caught in the blades check under the deck & see if there is & also try spinning blades by hand & see what happens
SOURCE: Will crank but won't fire
To run, the engine needs fuel/air mix, compression, and a spark. See if you can narrow your problem down to one of these. Remove the plug, then connect the plug wire and set (or carefully hold) the base of the plug against the cylinder head. Crank the engine and see if there is a spark. If not, the problem is in the ignition system.
If you see a spark, replace the spark plug. Remove the air filter and pour about a tablespoon of gasoline down the carburetor throat. Crank the engine, being careful to stay away from the carburetor in case it backfires. If the engine fires and runs, then it probably is not getting gas (fuel system problem), or not getting enough gas (carburetor or choke problem).
Compression problems are less common, unless the engine has been abused somehow. You can check for compression with a compression gage. Remove the spark plug, install the compression gage in the spark plug hole, then crank the engine with the throttle open and the choke off. If you get at least 60 or 70 psi when you do this test, the compression is probably not the problem.
NO JUST BE CAREFUL ABOUT HITTING THINGS
