LG LTM9000 Microwave Oven Logo
Posted on Apr 01, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Emerson Mwg9111sl microwave blows 20 amp internal fuse instantly everytime.
Less than 1 year old, turned on one day loud transformer noise then blowed 20 amp internal ceramic fuse. I know air conditioners not microwaves! It has the grill also, could it be the problem? The store is no help. Raising 2 grandchildren alone cant buy another one right now, hope someone has some tips. I have great respect for your tech. help. Thanks!
  • cz52 Apr 02, 2008
    I believe the fuse i am talking about is the same one. Blows instantly, still has same problem. Thanks
  • Anonymous Apr 21, 2008
    I am no electrician, but I can put my own computer together from scratch with parts from computer supply houses. This thing just quit without any signs. It went like the house fuse had switched-off or blew, but did not.
    I suspect my Emerson fuse blew internally. Fort Knox is not as protected as this thing's rear end. If someone could please e-mail me instructions on repairing this fuse replacement, I would gladly compensate. Thanks.
    [email protected] (423) 253-6249
Anonymous
Level 2:
  • Expert 185 Answers
  • Posted on Apr 01, 2008
Anonymous
Expert
Level 2:
Answers
185
Questions
Helped
80829
Points
308
Check your thermal fuse its about 2 inches long white on the outside black on the inside it has 2 wires going to it check for
cotinuity becareful of the capacitor you need to disapate that first by touching the two teminals together with a screw driver
Kitchen aid microwave blow 20 amp fuse on start.
Hello James
Having a 20 amps fuse is a bit high in todays standard as 15 amps fuses are recommended these days - they do not want too much current to go through the house wires.
Better to buy a new microwave as this microwave could burn down your house.
On model mh1160xss-0 whirlpooll microwave the fuse blows everytime you turn on cook
The magnetron is shorted or the inverter board is defective if microwave is 7 years old or less.
2answers
Microwave blows the fuse when you push the start button on the panel
This will be either a faulty door interlock switch or High voltage component. You will need to remove the outer cover after first disconnecting power. Discharge the high voltage capactitor!
Check the door switches are operating correctly if so move on to the high voltage components starting with the transformer
4helpful
Emerson Microwave stopped working
Have 1 of 2 choices, the main fuse or the control board for the front switches and clock. primary of the small power transformer has opened. Unplug the unit and take case off and measure the fuse with an ohm meter. if u read 1 ohm or less then fuse is good. then measure across the main power plug tips. If read open then the power transformer is bad. Need to replace the board as not sure if transformer is available.
2helpful
My Emerson Microwave Model # MWG9111SL keeps blowing fuses..
You have a shorted high voltage capacitor.
Here is a link you or someone you know can use to test it, but please read the safety info:
http://www.gallawa.com/microtech/cap_test.html
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020. Get help locating a servicer or parts at 1-800-695-0098.
Emerson parts are distributed by Fox International and their number is 800-321-6993. Or you might try e-mailing [email protected]
2helpful
Emerson Microwave oven and grill MWG9111SL
[email protected]
i have the same problem too! please help if you can.
Microwave emerson not turning ON
That makes it sound like a bad high voltage transformer.
Do you detect any burning smell?
Do the windings of the high voltage transformer seem blued or blackened?
They should be copper colored or maybe a little darker due to the varnish.
1helpful
Dead replaced fuse now makes loud noise
Yes that noise is causing your fuse to blow. Machine gun sound sounds like the High Voltage Capacitor or High voltage diode is bad. (Loud humming sound is usually a bad magnetron or bad power transformer). Most of these parts are inexpensive, except for the magnetron. But most of the repair bill is most likely going to be for labor.
Based on your model, it looks like an over the range microwave. And to fix any of these problems require the removal of the microwave from the wall. So its up to you if you want to deal with that hassle. But you also have to consider that you'll probably have a hard time trying to find a new microwave that will fit.
16helpful
3answers
Microwave keeps blowing fuse
If it blows the fuse as soon as you hit the START button, it's almost certainly a shorted high-voltage capacitor.
If it blows a few seconds after you hit the START button, it's probably the high-voltage transformer. You'll possibly also smell a faint electrical burning smell from the rear vent after you shut if off.
If it blows the fuse as soon as it's plugged in, you probably have a shorted door switch, a shorted varistor, or an internally exposed wire shorting to the chassis, etc.
1helpful
2answers
Microwave troubleshooting...
My GE spacesaver microwave all of a sudden stopped heating up things. The lights, fan, turntable, etc. work, but nothing is heating up. Any suggestions?
Top LG Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
