I'm looking for any solutions to try and fix this. My Fridgidaire FRS26R4A fridge side freexes everything on the fridge side from top to bottom. A gallon of milk freezes in about 1 day and I did you water trick and the compressor just never turns off I guess. Can you please help advise from here? Thanks.
Sounds like the damper isn't closing or the thermostat isn't working. I've seen these dampers freeze open and it basically turns your food side into a freezer side! Look at part #115 on this site. Take a mirror and look way back in the upper corner to see if you can see the little damper window is open, I'll bet it is staying open all the time pushing the freezer air into your fresh food side. http://tinyurl.com/5bnk6f.
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
