Does anyone have any ideas? My Indesit WG1130d washing machine has begun to leak ocassionally when it reaches last cycle. For every 10 times we use it, it will leak 5 times, and when I look at it from underneath I can´t tell where its leaking from as none of the tubes seem wet. Can this be fixed or is it time to get a new one?
SOURCE: washing machine blown fuses
Hi - had a similar problem with about 3 different makes of washing machine - the RCD switch on the main household fuse box was continually tripping . Nobody could give me a right answer . Eventually ended up with a Hotpoint . Felt sorry for the delivery guys from the electrical retailers having to keep dragging machines in and out .
SOURCE: indesit w123 washing machine
hi had a similiar problem on a year old washing machine after 3 engineers later who 1..put in a new circuit board...did not work 2...put in a heating element ...did not work 3...techican engineer..put in a new motor and repalced air pressure switch...bingo did work if your drum is turning slowly and does not wash how very well you may find ur motor is getting worn out..a problem..?? b careful they r £90 so make sure its that b 4 u change it my machine started to fill then almost immedately emptied out..then tured off then i had the flashing lights hope this is some help to u
SOURCE: indesit washing machine model WM 110 6kg
There are shops in Dubai which could help you. And lots of Philipinos in Dubai - they could surely help.(!) Wil try to get you an email of a shop.
SOURCE: indesit w93 washing machine fills with water but doesn't start washing
Hi there. I have an old model, the indesit WM12. Never counted the flashing light (yours was 10) but my dial started clicking constantly at the drain part. I called Idesit and they told me it was a blockage in the filter.
The filter they speak of it located, on mine, at the front of the machine at the very bottom on the right. It is a black dial about 3 - 4 inches in diameter. Unscrew that anti-clockwise (a real pain because so much water comes out. My wife and I unscrewed it, filled a baking tray with water, screwed it back up, emptied / substituted tray then same all over again - until empty. Though putting it on drain again and again helped at same time). When I pulled out the filter found a 'colour catcher' sheet in it. We used them first time ever the other day. Removed that, gave filter a wee clean and, hey presto, all is working again. Hope that helps. Jim
SOURCE: indesit washing machine wdg1295w blowing fuse
Proberly carbon brushes in motor,Can be supplied if req.grandadfixer
