What parts go to a Kirby Shampooer?
There is a shampooer head with shampooer brushroll, water tank, small hose that hooks to the tank, collection tray
Need to use the Kirby shampoo. It goes down as wet suds but you pick up the suds with the vacuum when it drys. Fill tank adding 1
cap full of soap (kirby soap only) per level on the side, this
attaches on the side where the bag is attached
After using the shampooer you need to reattach the vacuum bag and main brushroll nozzle as though you were just vacuuming up dirt.
Instructions:
Lift the front of your kirby up (front part with light) open
the handle on the dail in the front (if epquipt), remove the
power head, put on height adjustment on highest level, turn dial on front
of power head until you see 2 red arrows facing each other, unlock
by turning knob, power head should come right off, get
shampooer out the power head for shampooer with collection tray,
make sure dial is set red on red, put on front of Kirby and lock
in, turn dial to green on green arrows, fill tank adding 1
cap full of soap (Kirby soap only) per level on the side, this
attaches on the side where the bag is attached, line up arrow and
notch and turn, to hook up hose put Kirby down to lowest
level, notched end of hose hooks in on tray other end on the tank,on/off switch refers to the foam, Turn machine on to lay the
foam & scrub carpet, take shampooer back off to extract the foam once it's dry.
Good luck.
Deluxe carpet shampooer
