From what I remember on this copier...... The software in the copier may be from another country.... OP or AP most likely the copier needs a new toner installed or could be a paper jam in the doc feeder. The codes were a bit messed up between different countries, I did not biuld them.... Good Luck
ok... I am tech... and I had the same problem... you need to install the generic postscript driver then goto this ip address (http://localhost:631)and tune the driver... if not you will only print from tray 1 and only a4 paper size...
AP = Adding Powder (toner) it's not an error
it's adding toner from the container into the developer unit while displaying AP. when there is enough toner in the container the AP will disappear and copies can be made when there is not enough toner in the container the toner empty light will come on.
