Hi,from your problem,it seems the problem is from the logic board,you can however use a mulimeter to read the voltage supplied by the board,if it reads a low amount of voltage it means the board need to be serviced and cleaned thoroughly,but if it reads no voltage at all meaning its not supplying no amount of power,it means the logical board is bad and needs to be replaced.
Thanks and take care
I was wondering if you were able to fix this issue? I am having the same problem. I know my relay is not stuck. so what would be the next step to check?
