Cars & Trucks Logo
Posted on May 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2005 5.3 vortec top in no oil pres just got truck good moter or bad moter
Anonymous
Level 3:
Guru:
  • Master 630 Answers
  • Posted on May 06, 2010
Anonymous
Master
Level 3:
Guru:
Answers
630
Questions
0
Helped
301317
Points
1797
Have to see if the oil pump strainer is clooged...oil ports clogged??? was the motor taken care of...valve covers loaded up with sludge??? pan comes off the rest is to be looked at...if she was run on no oil pressure I sure would be suspect of this motor being in poor condition. Does it run???? Is it knocking?smoking? banging or clunking? if not put a gauge on the oil pressure sending unit hole and see if it really has no oil pressure or perhaps it has a bad sender?
How can I fix my car with the oil light coming on. The engine does intermittent jerking during driving
Oil light usually indicates LOW oil pressure.. Which will kill your engi ne and cause very expense repairs. FIRST Check oil level, If the level is good. You need to find out if the engine really has low oil pressure. A new oil pressure switch is about $8.00 you might start there. If the light still comes on its a good posibilty your car has bad oil pres.. To find out for sure you will need to install a Pressure guage and check the actual pressure.. If the Oil Level is good and you still have low oil pressure The engine has internal wear or damage.. You should not drive it till you fix the low pressure problem. rebuild or replace engine. The intermittant "jerking" can be unrelated to the oil pres problem or you engine is going away because of the pressure problem.
How do set time on 99 chevy blazer vortec v6 4.3
That could be correct, or 180 degrees off. Top dead center on the crank shaft can be on the intake or exhaust stroke.
1helpful
Where is my fuel pressure regulator located at on my 98 z71 chevy
If its the vortec engine everything is under the plastic intake on top of moter.they have plastic tubes under there which are called popet valves. Don't want to break them.they can make the moter black smoke and run bad if cracked.
3helpful
Where is the oil pressure sending unit located on a 2005 Chevrolet Silverado 5.3 liter vortec.
Its in the rear/ top /center. Hidden alittle, you can get it out with a special socket and it's not hard to access.
3helpful
2answers
Lifter
It could be lifters but its more likely that your not getting oil to the top right away. Probably plugged oil passages in the cylinder head. Remove the valve covers and clean it out. Change your oil and see if it helps. The damage may alreay be done though
1helpful
Water in oil
Hello, it seems that you have intake gaskets leaking. I'll bet you have the vortec 350. This is a common problem with the vortec, Gm uses plastic intake gaskets and they blow out over time usually to the externally but yours is internally.It is a pretty easy fix for the average mechanic to do. Thank you
Top Chevrolet Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Chevrolet Expert? Answer questions, earn points and help others
